Got big-block?
![]() Join Date: Jul 2000
anybody make smooth cowl covers?
I'd like to have one that's been smoothed with no leaf catcher/vents. Anybody know of any aftermarket ones...or have one for sale?
Thanks, SC. |
Where's my beer?
They're not made aftermarket as far as I know, your best bet is make your own, you have the risk of buying somebody else messed up project that didn't turn out as good as they expected.
Do a search, there's a couple of threads where board members made their own, not real hard to do. I plan in doing my own.
Paul How do you make the invisible, visible?.........You take it away. |
I have heard people saying that they have experienced cooling problems when they have done away with those vents. Just something to think about
Just sitting here contemplating contemplation. |
Cowboy Fan for Life!!!!!!
Will someone explain exactley what the purpose of those vents are? Thanks........Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
![]() Join Date: Aug 2001
From what I've seen it is designed to provide air to the side vents under the dash - Everything else motor related is sealed off.
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
Wiseass secured himself a BAN
It supplies air to your heater/ac vents. If you cover it you will not have any fresh air going into the cab.
67FSD is correct.... but, if you run aftermarket a/c or don't mind rolling the windows down it shouldn't be a problem.
One word of caution: when getting one welded up, keep it bolted to a cab to limit distortion.
I had a cowl smoothed and they screwed it up bad, I went to put it on the truck and it was straight.. I got one side down and then the other was like 2" high.. I had to toss it.. Make sure they do the majority on the truck if possible.
69 chevy c-10 longbed 89 mazda b2200 03 dodge ram 1500 02 honda accord IF SIZE DOESNT MATTER, THEN WHY ARE YOU AFRAID OF ME? |
Gotta Startem Early
I seen a chromed smooth cowl on a truck once but not sure where he got it from. It was aftermarket though.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
Member since 2000
i got a quick and easy idea. Get a blazer , smooth the cowl and take the top so you won't have to worry about fresh air getting inside. I'm going to smooth the cowl out on mine, i was also tipped off about keeping it bolted to the cab of the truck while working on it.
mine -
Sounds like people who welded these didn't set up a jig to help control the warpage....or tried to weld to much rather than tack welding....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
