ran out of money
how many of you with crate engines?
i was wondering how many of you have crate engines in your trucks.
What crate engine is it and how did you like it? looks like my block is cracked so i am exploring all my options Thanks Rat
Modify everything, leave nothing alone!~ ![]() ![]() |
I'm probably one of the few, but I have three ZZ4 350 crate engines. Thumbs down on all three. All three have been apart with very few easy miles. I did my own engine on this last K20.
I've got the regular replacement 350 in mine. I put vortec heads on it along with an Edelbrock cam, manifold and carb. It's been in the truck for 7 years and runs great.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
I've got a 350 with rpm air gap, edelbrock 600 carb, and stock heads. Works good for me.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
1FINE69
ZZ3 350 only had trouble with a broken valve spring so far after 40k miles.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
Ditto on the ZZ engine broken valve springs. I had that on all three as well. One even cracked the aluminum head while I was towing a trailer across Indiana....not a good trip....
1FINE69
Any idea why the springs are a problem on a motor that should be a mild street motor with similar components to the ZZ4?
1FINE69
I rarely run this above 3500 rpm and drive only a short distance to work and rare occassion freeway driven. Mine only suffered some bent pushrod(s) , I guess i was lucky it wasn't worse.
ran out of money
all good things to know thanks for the replys everyone
Thanks Rat
#10 | |
MOVE OVER
Dean,, you weren't running them like that car in your Avatar, were you? ![]() ![]() Just Kidding.... ![]()
No matter where you are..... There you are... Buckaroo Banzi |
I heard that the springs were defective. I replaced all of mine with new ones. I never abused mine either. They finally replaced the cracked head, but only because I know the service manager very well. I haven't torn down my last ZZ4 that had a problem because I was so frustrated. It is still on the stand. I'm guessing it has a broken piston.....
That is a LT5 ZR1 Corvette in my avitar. I'd never do that with my ZR1. I've never completely understood those burnout contests....lol
#13 |
I put a replacement 350 in mine 4 years ago and no problem.
#14 |
I recently put a ZZ4 in a friend's 53 Chevy half ton. Man, does it run now! I hope Chevy has gotten over the problems you guys had, or I'm sure my phone will ring. So much for a favor!
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
#15 |
I have the GM fast burn 385 in my truck. I have almost 30,000 miles on it had no problems with it. I drove it like a gramma for about the first 3000 miles, but since then I've driven it pretty hard. Just regular oil changes. Using Mobil 1 and wix filters. I'm very stoked on it.
72 Chevy LWB leaf spring rear,SBC 385 Fast Burn,Art Carr built 700r4,3.73 Eaton posi,one piece windows,lowered 4/5.5, 60/40 seat, shaved turn signals,shaved reverse lights,shaved stake pockets, stainless steel 21gall in rear, c-notched, vintage air,ps,pb,currently doing body work. 68 Camaro conv.327,turbo 350,pb,disc brakes,built it for the wife 38 Chevy Coupe on the back burner LIFE IS GOOD! SMILE |
#16 |
WILLY FOR PRESIDENT!!
I have just your basic bone stock 275 hp. 350 crate. I put an weiand intake and holley 600 carb. It has about 23,000 on it and have had no problems. I haven't been really mean to it, but it was been on the drag stip and on our black top drag stip around home.
Stanford
"He's a high tech REDNECK." George Jones '67 C/10 FOR SALE!! $600, runs, strait grill, good parts, or beater truck '68 GMC K25, 4x4, current project '71 Custom/10, Crate 350, My Baby!! '97 Pontiac Grand Prix GTP |
#17 |
I have a ZZ3 but haven't ran it yet. You other guys with the ZZ engines have me worried now.
#18 |
![]() Join Date: Feb 2004
I put a new Goodwrench 350 in one of mine. I changed out the cam and added a mild Edelbrock cam. lifters, performer intake, and 1604 performer carb. It has an HEI distributor and Hedman headers going into a 3-inch single exhaust with a flowmaster muffler. Sometimes I pull a 4000# boat with it and I have put over 35 K on it and it barely uses a quart between 3000 mile oil changes. Sometimes the Edelbrock lifters make a little racket on start up when it gets down to 0 F, even on synthetic oil. Problably more leakdown than the stock lifters?
I think the 350 goodwrench is a good deal if you don't need more than 300 hp, but I went with a local shop for my recent 350 rebuild on my '72. I wanted more grin factor on the two wheel drive machine. Hey, but its a dry cold. Brian in MT |
#19 |
my gas saver
had a 4 bolt jasper engine and it was one of the best i`ve ever had.
#20 |
Got a 502HO in mine -no problems yet ( does use more oil than it should-no smoke>other then tire smoke< no leaks-runs like wah-hoo!
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#21 |
Also have installed a 454HO in a 81 Elky,ZZ4 in a 71 Camaro, 350-330HP in a 64 SS Malibu, 2 GoodWrench 350's--no problems on any of these yet.
#22 |
![]() Join Date: Dec 1999
I have a ZZ-4 and LOVE it!!!!!!!!!!!!
#23 |
Yeh It's Fast
Crate Engine
I have a BB 502 HO in my truck and I really like
![]() ![]() ![]() ![]() Click here to view pictures of my truck ![]() ![]() ![]() ![]() Zwijndrecht, The Netherlands Europe |
#24 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I have one in my 69 truck, my 77 Blazer, and my 54 Chevy car. I have put in literally well over a hundred at the dealer where I worked. The Goodwrench is a great engine.
#25 |
![]() Join Date: Nov 2003
I put a Goodwrench 350 in a 71 Suburban seven years ago, still running strong and the guy that now owns it drives it hard.
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight! 71 Blazer, ex-4WD...Bought it that way 55 GMC 55 Belair 2dr HT 67 El Camino |
