03-02-2004, 11:06 PM | #1 |
Lifts=brake line extending using 2wd lines
I discovered a handy way to extend the rear flex brake line on 4x4 by using a stock 2wd unit. After the previous owner of my K20 installed a 6" lift he just let the rear line hang loose in the bracket to gain necessary length. I took the original rear flex brake hose from a 2wd 3/4 ton parts vehicle and discovered it is approx 4" longer than the 4wd 3/4 ton. Waalaa! Bolts in like factory!
'72 4x4 Blazer (in the works) |
