Old 03-04-2004, 12:56 AM   #1
tjm52
Rear end Toast!What Fits?
Hi! I really want to keep my 65 C10 a 6-bolt, but I have discovered that the diff is shot with a capital S. Both axles and bearings,crown and pinion are badly pitted,spider gears the same,all the internal bearings too...The only thing any good is the housing and I really cant afford to replace all the insides. 64-72 coil susp. only? Can I rob from a newer 12 bolt for the center section and go find some used axles? Is there a 3.5ish ratio around so I can cruise safely around 75? 250,mild cam,headers,stock intake.Just learning! Tom
"Daily Drivers....Eh!"
tjm52 is offline   Reply With Quote
Old 03-04-2004, 09:27 AM   #2
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
tjm52..................60-70 rear ends will bolt right in if you want to keep the 6 lug.............71 andup went to 5 lug.........hope this helps..............HEMMIT
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 03-04-2004, 09:24 PM   #3
zenish
i would get a 65-70 rearend.the panard bar is different on a 64 or earlier.i don't know if you can use the earlier bar.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 03-04-2004, 09:55 PM   #4
cochran63
cochran63's Avatar
the local salvage yard sells 99 and up disk break rearends for 450$ 6 lugs and disk brakes. If you arent too far away i have a low mile rearend in a 70 chevy that im parting out. Im asking 75 for it.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 03-04-2004, 10:47 PM   #5
tjm52
Sorry, 1500 mi away!Thanks anyhow.I'm in a good parts area and as soon as the snow goes the hunt is on...Should find one for a fair price but lots are ruined by rust,condensation.
Old 03-08-2004, 04:06 AM   #6
Slammed66
Needs a Big Block
Slammed66's Avatar
I would recommend one from a 69-70 as its still a six lug , with 3:08s as an option , I think that would be optimum for the truck your building right now , I know we have a couple at the shop im not sure what he charges for them tho , there is a really good old style wrecker east of bowden, theres a good possibility he might have one also , if you want to stay 3:73 Im changing the rear out of my 67 soonish for a 5 lug posi. we'll get something figured out for ya Matt aka primer66
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 03-09-2004, 01:05 AM   #7
tjm52
Thanks,Matt! I'll be on a serious hunt pretty soon, snow's starting to melt!
