Old 03-04-2004, 02:15 AM   #1
sam's 72
Who has a Ford 9" under truck
I am going to put one in my truck. Was wondering just how you guys did yours? I have never done a conversion like this before. I tell you what I am think. I am going to find one that measures close to mine in length. Then once I get it, measure where my brackets are at on mine. Then cut them off mine, weld them on to the 9" is this the route you went when you set your up?
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 03-04-2004, 05:22 AM   #2
68LSS1
68LSS1's Avatar
I'm putting an Explorer 8.8 with rear disc on mine. I originally started looking for a 9" but I came across this brand new 8.8 with 3.73's and disc brakes for around 800.00 so I'm going to try it. I think your rear should be about 58" flange to flange so you'll need to find one from a 77-81 Versailles/Granada (58"-58.5"), 66-77 Bronco (58"), or 73-90 F100/F150 (58 3/4"). It's going to be hard to find a narrower 9". I also want to mini tub my truck so going with the 8.8 gave me about three more inches (narrower). Keep in ming all 8.8/9 rear ends are going to have the driveshaft at an angle slightly to the right side as they are all offset that way (about an 1-1 3/4 if I remember right). Only way around that is aftermarket built to your specs. I have a trailing arm set up so I got new brackets from here at the advice of another board member.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 03-04-2004, 11:37 AM   #3
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
http://www.currieenterprises.com
Not cheap but a direct bolt in.
Both wheels make marks now
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 03-04-2004, 04:03 PM   #4
lost wages
lost wages's Avatar
measure from drum surface where the wheel mounts, the 12 bolt drums are larger than most of the 9 inch drums, i narrowed one side of mine to get the pinion centered, had new axles made from moser.
lost wages is offline   Reply With Quote
Old 03-04-2004, 04:48 PM   #5
crazy4chevs
crazy4chevs's Avatar
Thats what I did! Got rear discs too.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
