03-04-2004, 07:05 PM | #1 |
headers & horns
can anyone explain to me the benifit of headers over ramhorns, i was told you get the same HP out of horns
03-04-2004, 07:19 PM | #2 |
Too many is never enough!
exhaust
I think it depends on your application. Headers will give you a little more flow over ram horns but IMO ram horns are the best stock manifold design ever made. Too many headaches with headers for me. The good headers that won't leak are too expensive and the cheap ones will only cause problems. I love my horns and won't give em up for anything else. I guess I'm biased!
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
03-04-2004, 10:36 PM | #3 |
its all about the +6 inches
With the exception of a few $99 headers...they aill all outflow ram horns. Even most of the cheap crappy headers will outflow, but some of them are still junk.
There are ways around the headaches of headers.The only headache I have with mine is one spark plug being a PITA. Other than that, they are 100% hassle free. |
03-04-2004, 10:45 PM | #4 |
PROJECT 7DEUCE
I agree with andy on the headdr's with one exception,the gasket's burn out alot... I finally went with the copper gasket's and have not had a problem since...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-04-2004, 11:22 PM | #5 |
A Question and a Comment
I am dumping my headers in favor of the RAM'S, but I have also been told by an "Ole'school" muffler man to install the RAM's without gaskets. He told me to snug them up tight, like 30ft. lbs and "WHalla!" no leaks, I will no next weekend, because I am putting them on with new heads, new intake, new valve covers, and 2 1/2 Pipe with 40 series Flowmasters.
03-04-2004, 11:29 PM | #6 |
Check out www.castheads.com
I've got their system with the ported Vette heads and mandrel bent exhaust. If anyone wants, I can post a couple pictures.
Toys: 72 K5 Blazer 74 Vette |
03-05-2004, 12:26 AM | #7 |
Skid....
Do they CNC port only the exhaust port or the entire manifold?
03-05-2004, 12:42 AM | #8 |
I talked with Randy Brzezinsky and he said originally they ported the entire manifold, but the dyno told them that there was very little difference, and not worth the effort. The largest gains come from just opening up the ports to a 1404 gasket. I ported my own with a die grinder using the gasket for a template. I did clean up any casting flash inside though.
03-05-2004, 01:29 AM | #9 |
Happy to be here
Hmmm? Scoti are you thinking what I'm thinking? No reason why we can't port our own, eh?
Yes skid, I would LOVE to see some pics of your set up. In case y'all don't know there is a "big" difference between the longer truck style 2" outlet ram horn exhaust and the Corvette 2.5" ram horns. According to Brzezinski Racing Products, they have tested various exhaust manifolds for the small-block. The stock 2 1/2” Corvette “Ram Horn” manifolds are 10 to 15 horsepower better than any other manifolds. When CNC Modified, the 2 1/2” Corvette manifolds are at least 20 horsepower better I'm going to say that pretty close to any $99 header
03-05-2004, 03:08 AM | #10 |
Picture of 2-1 going into dynomax rv muffler (flows for 500 hp)
In front of cross member Passenger downtube (2.5" mandrel pipe) Drivers downtube Another pic of 2-1 collector picture of vette ram horn (sorry, I don't really have a decent one)
03-05-2004, 07:06 AM | #11 |
Skid....
It looks like you used Brzezinskys collecters (compression fittings) as well. How do you like them? Worth the $$?
03-05-2004, 09:25 AM | #12 |
I have two sets of ram horns one set dumps straight down like your pitcure of the vette ones. the others angle back are these just for trucks &what years. thanks biglou.
Certifiably crazy person |
03-05-2004, 09:55 AM | #13 |
2WD angle back and 4WD are straight down. The straight down ones are easier to find around here due to the fact they were used on a lot of passenger cars.
03-05-2004, 10:25 AM | #14 | |
Happy to be here
03-05-2004, 09:12 PM | #15 |
N2trux
Mine are the same ones as the ones you posted. I hack-sawed and ground off the generator mounts, and faced the ground portion to the fire wall, reversing them left to right and right to left. It's really hard to notice where I ground them.I got them from my local GM dealer out of the chevy power catalogue.
03-05-2004, 09:19 PM | #16 |
Scoti
Yeah, I bought the Brzezinsky 2-1 collector kit with the mandrel bent elbows. I supplied the straight pipe. Instead of using a donut gasket, the kit comes with a machined, metal donut tig-welded to the pipe that bolts up to the manifold collector. So far no leaks!
03-06-2004, 06:22 PM | #17 | |
Happy to be here
Re: N2trux
