Old 03-05-2004, 01:28 AM   #1
ocbaud
Garage Queen Material
installed my tranny cooler today(truck update)
yeap, it was really, really easy to install. i got the b&m 24,000gvw supercooler.
more parts are on the way and should be delivered next monday. Next week will be a fun week. i'm gonna clean the inside up some, since its a mess from me working on teh engine and storing crap in there.
also, should i install my MSD 6AL box in the cab or under the hood? i was thinking of installing it in the cab, under the glove box, and run the wire to the distrubtor out the old ESC hole.
ocbaud is offline   Reply With Quote
Old 03-05-2004, 01:38 AM   #2
Prerunner1982
Prerunner1982's Avatar
eric, putting the box there would keep it well out of any weather.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-05-2004, 01:40 AM   #3
bigblock73
yeller
bigblock73's Avatar
I am running mine on the inside behind the glovebox. You could mount yours there as well but attaching it to the firewall might be difficult if your A/C and heater stuff is there.
The 6AL is different than the 6..it has rubber "absorbers" that go between it and the mounting surface...so simply screwing it to the firewall is not an option...or at least according to mnfr specs.
bigblock73 is offline   Reply With Quote
Old 03-05-2004, 02:03 AM   #4
Mike76251
I checked my MSD box after a few long pulls and it gets pretty warm. I think you really need some air flow over the fins and it wouldn't get any inside.
Mike76251 is offline   Reply With Quote
Old 03-05-2004, 02:30 AM   #5
apstguy
LED King
apstguy's Avatar
What kind of fittings are on the end of the supercooler? Did you just run rubber?
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 03-05-2004, 02:41 AM   #6
ocbaud
it came with nipple fittings on the cooler.
yes, i used the rubber line they supplied. i figure later on down the road, when i get the engine and other stuff done, i can install it a little more neatly
Old 03-05-2004, 08:35 PM   #7
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Eric can you post a pic of how you mounted it? I'm trying to get ideas for mine but having no luck. I've got the holes drilled out for the lines to pass through but with mine being different support than Mike's I need to see all the options.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-05-2004, 08:50 PM   #8
Low87on20s
Live from Atlanta
Low87on20s's Avatar
Kind of off topic...
In my old '88 F*rd Mustang Coupe, I mounted the MSD 6al, the coil, and the 2-step in the interior behind the glove box. I mounted them all on a piece of 3/8in thick plexi-glass and mounted the plexiglass to the inside of the firewall. MSD makes a coil "thru-put", that mounts through the firewall, to take the coil wire from the coil (inside the vehicle) to the distributor. It was a pretty slick setup. If I can find pictures of it, I will post them.
Paul
Low87on20s is offline   Reply With Quote
