03-05-2004, 01:44 AM | #1 |
Garage Queen Material
distributor shims?
i saw these in jegs. would i need to get some since i've had my block zero-decked?
03-05-2004, 01:52 AM | #2 |
no. shims are to take end play out of a distributor. yours is new so it wont need them
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
03-05-2004, 01:54 AM | #3 |
Has nothing to do with zero decking your block if we are on the same sheet of music....generally if my memory is working there should be in the neighborhood of 30K thousandths play betwwen the dist. gear and the housing...the shim..ava from gm...comes in a one size fits all size. Generally the shim wears into the dist. housing on high mileage dist's....so i replace the shim and rerun the dist as long as the shaft has not oblonged the housing...
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
