Old 03-05-2004, 03:26 AM   #1
Paso76GMCstepper
Paso76GMCstepper's Avatar
Wiper Motor and Valve Covers
Hey Guys,
I have a question about the windshield wiper motor. The one I have now doesn’t come on. The used one I bought off of Ebay doesn’t work. How do I test if it’s the motor or the switch, wiring, etc.?? I have the dash torn out so getting to the switch is a piece of cake. Any info would be much appreciated.
Also are rubber valve cover gaskets for a 350 with Mickey Thompson valve covers ok. Do u use any sealant?
Thanks again Tony
Tony
"Life is a Team Sport"
To the memory of the Hendrick Motorsports Plane Crash Victims
Paso76GMCstepper is offline   Reply With Quote
Old 03-05-2004, 03:56 AM   #2
BladeX
to my knowledge ya use RTV silcone stuff with corkboard only.
Rubber is just byitself.
BladeX is offline   Reply With Quote
Old 03-05-2004, 03:57 AM   #3
Paso76GMCstepper
Thanks.
Old 03-05-2004, 07:55 AM   #4
1FaastC10
1FaastC10's Avatar
bladex, RTV should never be used to install valve cover gaskets. doing so is an open invitation for leaks. save the RTV for the intake.
1FaastC10 is offline   Reply With Quote
Old 03-05-2004, 11:05 AM   #5
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Since the switch is easy to get to, check for 12V at the switch, and then check to see if the wires running to the moter get power when you move the switch through the positions. Don't forget to check your fuses.
NeCrOmAnCeR is offline   Reply With Quote
