Hello all,
Need some advise on the small, glass sized, transmission fluid container you put the fluid in. Mine was mounted on the drivers side fender originally. I changed the fender out for a nice one and remembered that I have seen these mount in different areas around the engine bay in others trucks. My question is, where is it suppose to mount? Reason is I am really trying to be as original as possable as I go on this truck. Thank you, Billy
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Are you talking about one of these?
its all about the +6 inches
You have a picture? The only glass anything under the hood I am aware of was the windshield washer resivour, but that wasn't stock on these trucks.
Andy, he said "glass sized" and it was mounted on the left fender and he has a big block, and lots of folks put ATF in their power steering resorvoir, so I think it's a BB p/s reservoir he's asking about.
If so, I can get him the factory spec measurements where to mount it. I just drilled and mounted mine on my big block swap over. The factory assembly manual has a pretty decent diagram as to where to put it. THIS IS NOT MY ENGINE, it is a picture off of this board of someone elses original big block truck.
Ahhh, I see. That makes sence.
Here is another one then. |
Okay,
I'm an Idiot today!! Yes, it is the power stering Resevoir. My truck was leaking Trans fluid all over the driveway so I had that on my mind while I was posting about the PS. reservior container. Sorry to cunfuse you both. Thanks very much for the picks!!! I would like it very much for a copy of the specs? Mine was mounted further back on the old drivers side fender. Andy. You know this is Billy don't you? When I get her up to par, I still owe you picks and a story for your longhorn web site. Thanks Tx Firefighter and to you Andy for the help. You guys are Awesome!!!!! Billy
The book gives two different mounting locations for the reservoir. The one in the pictures above is the normal location. The trucks with dual batteries had them mouted further rearward.
I'll get a picture of the page posted up for you when my wife gets home with the camera.
