Old 03-07-2004, 12:53 AM   #1
ucmydust68
fuel
need advice on where to put valves??
just wanted to see where you guys put your valves. im trying to figure out where to put mine.
this would help me alot, i want to do this before i put my cab on, thanks alot!!
chris
72 w/67 front clip
415ci
fuel injection
t56
air ride
18/20's
ucmydust68 is offline   Reply With Quote
Old 03-07-2004, 04:51 PM   #2
ucmydust68
fuel
TTT
72 w/67 front clip
415ci
fuel injection
t56
air ride
18/20's
Old 03-07-2004, 05:03 PM   #3
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I am planning on putting my things under the bed at the front of the cab. Maybe in the bed at the front near cab. I am running all electric valves and gauges so air lines will be minimum.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 03-07-2004, 11:45 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
On my 77 Cheyenne, they are mounted on a custom panel under the cab where the "other" gas tank would be if I had duals.
Heres the panel they are mounted on-
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-07-2004, 11:46 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
And here they are mounted under the truck-
Old 03-08-2004, 01:35 PM   #6
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
I made a set of brackets for mine out of angle-iron that mounts the the outside of the frame. I am only running a F/B system with SMC valves. They are mouted underneath the doors and make for a nice sound effect when I drop it
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 03-11-2004, 12:36 AM   #7
loweredd
www.loweredd.com
loweredd's Avatar
Mine are on the passenger side where the gas tank would have been too. My tank is also, and my compressor. When I take the other tank off and put in the fuel cell, I will add another tank on the drivers side, and put an engine driven compressor on the LT1.
loweredd is offline   Reply With Quote
