Old 03-07-2004, 12:54 AM   #1
robby
Semper Fidelis
robby's Avatar
big block engine code help
can anyone help with my new big block codes?
pad in front of passenger head C8F 329409
on pad above timing cover TD8 121 TST
Any help would be great!
It is supposed to be the original 454 out of the 78 pickup I have.
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 03-07-2004, 01:17 AM   #2
superchevy
Got big-block?
superchevy's Avatar
Get the numbers off the rear of the block above the bellhousing on the drivers side...that is the casting number. The numbers on the pass side are the date codes. Then go here http://www.mortec.com/bbc.htm and see what you have.
superchevy is offline   Reply With Quote
Old 03-07-2004, 01:29 AM   #3
Rod
I like decoding them with the suffix codes... you can find yours here... http://www.nastyz28.com/sbchevy/spcoded.html
78 454 from 3/4 or 1 ton 250 hp.
The site has good decoding information
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-07-2006, 01:39 PM   #4
nez71
Re: big block engine code help
Thanks that confirms it, at least is says its an original 402 that came in a 1970 GMC pick-up. The lady i bought the truck from said her husband bought it new in 1970, she said he pulled a 21 foot boat and it had a big 10 foot cabover camper on it that was put on shortly after they bought it and never taken off (until I got it). She said her husband wanted more power from it when pulling the boat and camper so she said he had an RV cam put in it to get more power for the mountains. She said it was only used to go to the lake fishing on the weekends. The interior is almost perfect cause the camper shaded it for all these years. the odometer reads only 58000K but the speedo cable is removed from the factory cruise so the speedo dosnt work. Im assumning it has less than 100K original miles, the little lady said it had sat for several years since he died. I drive it as my daily driver with no problems but a slow tranny leak from the linkage for the shifter. Sorry to ramble but I thought it was a good story to share.
Heres a link to a couple pics. Thanks again for the info guys!!!
http://pg.photos.yahoo.com/ph/nez71/...KwonFBgU7ZqHxR
nez71 is offline   Reply With Quote
