Old 03-07-2004, 02:41 AM   #1
brodykelly
stock is where the money
72 K5 compressor switch?
i replaced the heater core on my 72 k5 and i didn't unplug what the shop manual calls "compressor switch" and it busted. does anyone know where i can get one at, its located about 6-8 inches to the right of the center hump on the bottom of the heater housing, it points straight up in the housing towards the roof, it has a 2 wire plug going to it, don't really know what it does and the manual doesn't explain, you have to get in the passenger floorboard and look up toward the hump to see it, this is an a/c blazer, don't know if it has anything to do with a/c or not, heater is working fine, any help would be great, thanks brody p.
brodykelly is offline   Reply With Quote
Old 03-07-2004, 02:54 AM   #2
Cruiser71
AKA Phillip Johnson, AKA BANNED
If I remember correctly, if that switch isnt working, your fan will not operate on high speed. Correct me if Im wrong.
Cruiser71 is offline   Reply With Quote
Old 03-07-2004, 09:00 AM   #3
brodykelly
my fan does work on all speeds, don't know if it should be or not. the inside of this switch has 2 copper fingers about 1-2 inches long , like i said i busted the housing for it so it won't stay in its hole, just wandering where i could get one, does anyone know what i'm talking about or am i not describing its location good enough? let me know cause if it has to do with the a/c, summer is coming.... thanks brody p.
Old 03-07-2004, 01:23 PM   #4
JimKshortstep4x4
Talking
You are describing it correctly, it is call an A/C compressor switch and it turns the compressor on. Chevy Duty has them, (PN 68-961) and I am sure other vendors carry them.
Jim
Old 03-07-2004, 09:40 PM   #5
danho
Pesemistic Optimist
danho's Avatar
I looked in some of my catalogs and they look to be going for around 15-20 dollars. A/C compressor switch.
HTH Dan.
1972 K20 Cheyenne Super Custom Camper- 4" lift & 35's, built TH350 and 355. Daily driver resto in progress.
1999 Yukon Denali- Wife's ride, hands off.
danho is offline   Reply With Quote
Old 03-08-2004, 02:18 AM   #6
brodykelly
thanks for the info on part numbers and the exact name, this site has been kind to this new member who is getting his feet wet on these old trucks, thanks again brody p.
