Old 03-07-2004, 11:33 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Talking Finallytime to fill hole's..
Gonna break in the new welder today I figure that I hav about 30 year's worth of hole's to weld up door handle's,marker light's ,steak pocket hole's and many other trim unused hole's to weld up... Got about 25 hole's to weld up on this door and a rocker to replace so much work I am not sure where to start..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-07-2004, 12:05 PM   #2
walker
walker's Avatar
I welded up a bunch on my new bedside a while back. I took a piece of 1" copper tubing, about 8" long, and beat the end flat and gave it a little bend. I use that as a back up behind the hole when welding it up. Just take it nice and slow, little spot welds not long plug welds. Also use one of those 3m wheels on a grinder to remove the paint first. Enjoy!
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 03-07-2004, 03:02 PM   #3
truck69
Thumbs up
I am also at that same point. I liked the truck but not with all that trim. So I am taking it all off then will have my brother take care of the welding. He has every do dad there is to weld. But one thing I am learning is...Its not going to be done in a day. I got the truck last July thinking it would be done this spring. Well...you have to pay for the roof over your head first and food each week. Plus the wife has a little something to say about the money. SO it might be a year or 2. I have a 69 Chevy camper custom as you can see below. Good luck with yours.
Truck69
truck69 is offline   Reply With Quote
Old 03-07-2004, 04:20 PM   #4
dinnut
dinnut's Avatar
are you completely shaving the truck? ie removing door handles and sidemarkers and all... thats what it sounds like from the first post.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 03-07-2004, 04:24 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Yes everything but the drip rail's will be gone roof seam gas filler cowl vent's heater box get pic's when I am done today... Later!!
MEMBER #6377
Project "7DEUCE"
Old 03-07-2004, 04:58 PM   #6
Gee_Emm
When you grind the welds down use a flap wheel disc instead of a solid disc. It will make the job turn out 10 times easier.
Gee_Emm is offline   Reply With Quote
Old 03-07-2004, 11:42 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
Yep used a flap disk and it sure made the metal work easier by not having to use filler...
MEMBER #6377
Project "7DEUCE"
Old 03-08-2004, 12:34 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
Some progress pic's from today!!!!! Finally I have made some progress as I have not touched my truck in about 2 month's due to being burnt out..
Before..
MEMBER #6377
Project "7DEUCE"
Old 03-08-2004, 12:37 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
Welded up 25 damn hole's in a door for trim and 3 set's of mirror's..
MEMBER #6377
Project "7DEUCE"
Old 03-08-2004, 12:39 AM   #10
FRENCHBLUE72
PROJECT 7DEUCE
Bed trim hole's welded up and ground smoooth..
MEMBER #6377
Project "7DEUCE"
Old 03-08-2004, 12:41 AM   #11
FRENCHBLUE72
PROJECT 7DEUCE
Mirror hole's on driver's side only had 5 hole's on this door..
MEMBER #6377
Project "7DEUCE"
Old 03-08-2004, 12:44 AM   #12
FRENCHBLUE72
PROJECT 7DEUCE
Weled up all unnessacary hole's in the dash.. Must have been about 15 different hole's for c.b. and radio e.q on the bottom side of the dash..
MEMBER #6377
Project "7DEUCE"
Old 03-08-2004, 12:53 AM   #13
FRENCHBLUE72
PROJECT 7DEUCE
Shave the inner door lock hole's...
MEMBER #6377
Project "7DEUCE"
Old 03-08-2004, 12:58 AM   #14
FRENCHBLUE72
PROJECT 7DEUCE
I know some people won't like this shot of rust free 72 door with the screw hole welded up... Gonna go with one piece glass so if anyone need's glass ,wind wing's or regulator's I woill take 60 buk's for both side's and shipping or they will hit the dumpster..
MEMBER #6377
Project "7DEUCE"
Old 03-08-2004, 01:17 AM   #15
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
i'm almost finished with the trim shave and stake pocket smooth portion of my project. i only have 1 side of the bed left to do.
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 03-08-2004, 02:18 AM   #16
Cruiser71
AKA Phillip Johnson, AKA BANNED
I counted 21 holes on the door, not 25.. LOL. Nice job on the screw hole. 72 doors.. Ouch! They are rare!
Cruiser71 is offline   Reply With Quote
Old 03-08-2004, 05:12 AM   #17
gonebad2
Merciless Butcher
gonebad2's Avatar
The best favor anyone can do for themself is ditch the flux coated wire and pick up a bottle. It makes so much less work for yourself. Plus you get the added bonus of using thinner wire and creating less heat. I used to have a Lincoln Migpak that got ripped off. That was the biggest favor anyone ever did for me. For whoever did it, if you're out there, I owe you a beer.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 03-08-2004, 09:32 AM   #18
FRENCHBLUE72
PROJECT 7DEUCE
Gone2bad I am really happy with the miller matic 135 even though I need to build a cart as hauling the bottle around and chainng it to the truck suck's.. 71 LONGBED sure take's for ever to fill up those damn hole's huh!! Thank's for the complement's guy's...
MEMBER #6377
Project "7DEUCE"
Old 03-09-2004, 02:54 PM   #19
Brad
Out of the carpool lane.
Brad's Avatar
When can you start on mine?
Btw, can you send pics of the wing windows to bassmaker(at)hotmail.com
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-09-2004, 04:53 PM   #20
busterwivell
I haven't started on the holes in my truck yet, been working on the Chevelle to get ready to take it to DelMar in a couple of weeks. Did get a Miller 135, also. It's great. I too have to make a cart for it, but not until after DelMar. That is, if we can afford metal by then. Priced that stuff lately?
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-10-2004, 02:12 AM   #21
nate68
hehe you filled every hole hehe
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 03-10-2004, 04:41 AM   #22
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
it looks like you filled the little rubber bumpstop holes for the ashtray. are you going to use the ashtray still? BTW: It's looking good. I'm not too far ahead of you, I've been sitting at the point where I need to clean out the drip rail and reseal it, plus pull a hail ding out of the roof of the cab. My truck has been primed from the roof down for a few months now. I haven't went any farther because the same reason.... "burn out"
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 03-10-2004, 09:28 AM   #23
FRENCHBLUE72
PROJECT 7DEUCE
Hotrod70 I am gonna fill the ash tray because I don't smoke and hate having unused item's on or in my truck... Do you need an ash tray as I have the whole set-up little stiff on the sliding part if ya need it let me know..
MEMBER #6377
Project "7DEUCE"
Old 03-10-2004, 11:47 AM   #24
Hotrod70C10
Low & Slow
Oh ok, No thanks, I don't smoke either.
4.5/6 drop
Old 03-10-2004, 05:35 PM   #25
nate68
ash tray = place for change or gas receipts
