Old 03-07-2004, 12:00 PM   #1
Smooth68
Smooth68's Avatar
Question Control arm caps
Can anyone tell me what size the upper and lower control arm caps are? Looks like I'm gonna have to either borrow or buy the tools to fit them as the biggest I have is 1 1/4" - thanks for the help!
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 03-08-2004, 03:07 PM   #2
72MARIO
72MARIO's Avatar
I used a flat jaw pipe wrench. Worked for me.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-08-2004, 03:26 PM   #3
SCOTI
SCOTI's Avatar
I've used either a pipe wrench or @ my work we have some huge cresent wrenchs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-08-2004, 04:02 PM   #4
Smooth68
Smooth68's Avatar
I've got a big pipe wrench, but I didn't want to take a chance on screwing up the caps - that might be the way to go.
Smooth68's Web Site
Old 03-08-2004, 07:01 PM   #5
SCOTI
SCOTI's Avatar
Just start them like a normal bolt & when you can't tighten them by hand, start using the pipe wrench & work slowly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-09-2004, 08:36 PM   #6
william 70 c/20
yeah take it slow...i think the torque spec for my 70 c/20 caps were 250 ft/lbs...
william 70 c/20 is offline   Reply With Quote
Old 03-09-2004, 08:55 PM   #7
Smooth68
Smooth68's Avatar
Thanks for the replies guys, but I'm trying to disassemble - I have a little bit before I am read to assemble
Smooth68's Web Site
Old 03-09-2004, 11:16 PM   #8
1971 Cheyenne
1971 Cheyenne's Avatar
The uppers are 1 3/8 inch and the lowers are 1 5/8 inch.
I know, I had to buy both wrenches last week to do mine .
That is for a 71 C10, It is prolly the same for c10/c20 but i'm not sure...
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 03-09-2004, 11:41 PM   #9
Smooth68
Smooth68's Avatar
Sweet! Thanks Cheyenne - did you replace the upper and lower control arm bushings? Any advice you can throw my way that would make the first time easier?
Smooth68's Web Site
Old 03-10-2004, 01:42 PM   #10
1971 Cheyenne
MAKE SURE that the threads are clean of paint etc. in the a-arms before you try to screw in the caps. it makes it VERY hard if you dont.
Also, make sure the upper shaft is perfecetly centered in the a-arm. Keep measuring from the side of the a-arm to a hole, then the same on ther other side. This is not crucial while you are doing it, because you can always spin the shaft to move it left or right, after it is all together. It's just gotta be in the middle when you go to put it on....
And ummmmmmmmm, just have patience, some of mine went right in, some of them went in like a %@&#. I think that was because some of my threads still had some POR15 in them though....
Hopefully this ain't too confusing..... anymore Q's just ask....
Brian
Brian Pal
