03-07-2004, 12:39 PM | #1 |
Next project: 1970 K10
Factory oil psi gauge install question
I installing a factory gauge cluster in my 68 that originaly had lights only. I need to know if a standard oil psi gauge install kit will work on the factory gauge? Is the fitting, ferrell, and hose diameter the same on the aftermarkets and factory gauges?
Thanks!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
03-07-2004, 01:02 PM | #2 |
its all about the +6 inches
Yes, it'll work.
You ARE aware that the guages is not a simple remove and install for the light inst. panel, right? If you simply plug it in, you will have some funny working lights, and a dead fuel guage. |
03-07-2004, 01:15 PM | #3 |
Yeah, I have already swapped out the under dash harness, and rerouted a couple wires under the hood. Thanks!
