What is this rearend?
This is in a 1970 GMC. The only thing I know about it are that it has limited slip and a pretty high gear ratio (3500 rpm @60mph).
70 GMC, SWB, 2WD, low |
Dana 44?
i think it might be a dana 60
I've been told it was a 60 but not by someone who is an expert. I am hoping for a definitive answer.
It is a Dana 60, I can see the "60" in the casting web in that picture. Is it a 6 lug semi-floater? If so, is it a big block truck?
Tim |
And it is a coil spring 60 for the naysayers who haven't seen one.
It is a 6 lug, and yes it is a colil spring truck. I don't know what a "semi-floater" is. No big block - 350.
#8 | |
Formerly yellow72custom
![]() ![]() If it is a full-floating rear axle it will have a hub assembly that pokes out past the lugnuts on the wheels, with about half a dozen bolts on it. The semifloating rear axles do not have this.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#9 | |
Seasonal Poster
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
#10 | |
Tim |
