Old 03-07-2004, 05:10 PM   #1
SixthFloorFreak
A Couple Conversion Questions
First of all, could a 2wd be converted to a 6 lug pattern?
Second, would the whole rear axle from a 99+ truck fit under my 84? I think it would be pretty neat to have the disc brakes, plus i have a friend that deals in wrecked cars that could probably find me one. If it would fit, what might i have to do to the brake system for everything to work right?
SixthFloorFreak is offline   Reply With Quote
Old 03-07-2004, 11:32 PM   #2
Prerunner1982
Prerunner1982's Avatar
the 70 and pre trucks were 6 lug. i dont think the axle would fit without some modification. may not be the same width, and the spring perches would have to be redone. probably among other things.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-08-2004, 01:02 AM   #3
1FaastC10
1FaastC10's Avatar
yes, a 2wd can be converted to 6 lug. install a pair of 1/2 ton rear axle shafts in your existing axle. you'll also have to getthe drums, and possibly the backing plates too. then, from the same donor truck, remove the front axle, trans, and transfer case, and complete steering/suspension setup, along with any brackets that you may need to mount said steering/suspension. convert it to a *REAL* truck.
1FaastC10 is offline   Reply With Quote
