Old 03-07-2004, 07:08 PM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
GMC C20 Questions
My stepbrother has a '70 GMC 3/4 ton longbox he has been trying to sell me for quite some time now. I finally got to look at it and drive it today.
It is an original Colorado truck, so the body is really solid. Needs 2 rockers and a small part of one cab corner, above the windshield, floors, and cab supports are rock solid. Unlike my '72, which needs alot of work in all the commonly rusted areas.
Anyway, it has a coil spring Dana 60 in the rear. It is an orignal 307 truck, with a granny low 4-speed transmission. The original 307 is gone, replaced with a very well running 327 from a 1962 fullsize car (i verfied it with the engine suffix codes).
So, what would the axle ratio in the rear be stock? I'm thinking 4.10, but the truck seemed really low geared so it may be lower. I have the axle ratios for a C10 figured out, but C20s are a different ballgame.
Also, which model transmission would this truck have in it?
I want to buy it, and he said he could proably hold on to it for me for a few years until i can afford it.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 03-07-2004, 08:06 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Either 4:11 or 4:56. If it does not state an optional ratio in the glove box, it's 4:11
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-07-2004, 08:12 PM   #3
MrGoodpliers
MrGoodpliers's Avatar
My '70 GMC 3/4-dana 60 equipped truck lists 4.10 ratio on the glovebox. Hmmm... I thought they only listed the ratio if it was an option, and I thought that 4.10s would be standard.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 03-07-2004, 08:13 PM   #4
lukecp
lukecp's Avatar
Thanks!
It didn't say anything about the rear on the glovebox sheet, only options listed on the sheet were the 4-speed tranny, special paint, and one other i forgot. Very plain truck, however it runs and drives great. Felt werid driving a truck with manual everything, i'm used to my '72 with PS/PB/AT. I kinda liked it though, lol.
Old 03-07-2004, 08:15 PM   #5
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
the famous sm465 is the most likely canidate for the tranny.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 03-07-2004, 08:15 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
I6 3/4 tons with certain trannys had 4:56 standard
Old 03-07-2004, 08:41 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The 1970 book doesn't have anything about gearing...it is kinda pathetic, however, the 71 shows 4.56 being standard gearing when the 307 engine is included, regardless on what tranny it has. Also, if the tranny is original, the SM465 is the only one that it could be.
Old 03-07-2004, 08:45 PM   #8
lukecp
lukecp's Avatar
Well if i get it i may have to pop the cover and count the teeth then. I did just make a trip from Colorado to Missouri at 70mph the whole way, so i would think it would have to have 4.10 gears to do that, however a 327 has a reputation for being a tight-rapping little motor.....
Old 03-07-2004, 09:30 PM   #9
Mike C
Mike C's Avatar
Originally the Dana axles have a sheet metal tag that has a part number and the gear ratio stamped on it. If some loser mechanic didn't leave it off after changing the gear oil, should still be there. Clean it off with carb cleaner and read gear ratio directly! Too cool.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-07-2004, 10:30 PM   #10
Longhorn Man
a 4.56 geared truck should be able to hold 70 no problem...they have pretty tall tires on there.
Old 03-07-2004, 10:42 PM   #11
lukecp
lukecp's Avatar
Once again, thanks for the help. I'll check the tag next time i look see the truck, if the tag is still there.
Another thing i was suprised at is that the frame on the C20 looks no thicker or no taller than the frame on my C10. Only difference i can see are stiffer springs, 8-lug wheel pattern, and the much beefier rear axle.......
Also, with 31" tires (which the truck has), online caluclators put it at 3460rpm@70 with 4.56 gears and 3111rpm@70 with 4.10 gears...
Old 03-07-2004, 11:01 PM   #12
Longhorn Man
There you go...3500 RPM is nothing to a small block.
your frame is pretty much the same as a 1/2 ton unit. If you look at the trailing arms, they are a little beefier too.
Old 03-08-2004, 09:00 AM   #13
CPNE
Resident Curmudgeon
CPNE's Avatar
Are your sure about this? My 71 GM resto pack shows 4:10 for all small block's and trannys combos except 307 V8 with powerglide or 350 or 307 V8 with a 3 speed column shift. Those got 4:57 gears. This is true for both Corp and Dana axles. (Dana's are actually 4.56 )
All 250's got 4:57 , the 292 got them only with the 3 speed.
The 402 got 3:54 dana only, except the longhorn with the leaf rear. It got 4:10 dana with the BB
Old 03-08-2004, 01:18 PM   #14
Duffy
Dana behind a big block
My GMC longhorn with original 402 has a Dana 60 leaf rear axle with 3:54 from the factory. This is behind a manual tranny of course (sm465).
Duffy
'72 GMC Sierra Grande Custom Camper
Duffy is offline   Reply With Quote
Old 03-08-2004, 01:30 PM   #15
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: Dana behind a big block
Duffy
My bad. I should have stated:
The 402 BB had only one option for rear end ratio which was a dana 60 with 3:54. Exception is the longhorn which allowed you to opt for a 4:11.
Your 3:54 rear is the standard RPO.
