Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-07-2004, 07:30 PM   #1
72bigblock4wd
Parting out '78 Suburban
Parts for sale. ** indicates no shipping on this item. Thanks!
Tilt/ Cruise Steering Column, exc. cond. with Key $90.
**Radiator Core Support, exc. cond. $75.
**Windshield, no cracks or chips. $50.
Taillight Housings/Lenses fair cond. $10.
I will also have a set of 5 steel rallye wheels, 4 w/caps & trim rings for sale, as well as a 5-lug 12-bolt rear end with 3.40 gears, I think it's an open rear end, but need to pull the cover yet. If there's any parts you're looking for let me know and I will let you know if I have any of them. Thanks!!
72bigblock4wd is offline   Reply With Quote
Old 03-07-2004, 10:40 PM   #2
Russell
Professional Grade
Russell's Avatar
I'm looking for a driver's side power window switch, both front door power lock switches, and the brushed aluminum trim plates / trimming.
The switches and alumnimum plate and trimming around the plate are shown here: I would also need the pull strap covers if they arn't damaged, I've only got one left....
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-07-2004, 11:11 PM   #3
72bigblock4wd
This truck has manual locks and windows. Sorry.
Old 03-09-2004, 08:19 PM   #4
72bigblock4wd
TTT
Old 03-09-2004, 08:24 PM   #5
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
What color is the interior? If tan can you tell me the shape and style of the trim on the front door panels? I'm looking for the manual style like you have but the trim level with the chrome trim (ring) around a part of it.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-09-2004, 08:29 PM   #6
72bigblock4wd
The door panels are not in very good shape. Too much sun and now the plastic is deteriorating.
Old 03-09-2004, 08:33 PM   #7
79BIG10
79BIG10's Avatar
Sounds like what I've got now
Old 03-10-2004, 11:12 AM   #8
79Suburban
I'm looking for the rear electric motor for the tailgate window and the plastic piece that bolts to the radiator support for the fresh air hook up to the air cleaner.
79Suburban is offline   Reply With Quote
Old 03-10-2004, 07:56 PM   #9
72bigblock4wd
The plastic piece is missing for the fresh air intake. I think that the rear window motor is good. I will see if I can get it out and I will let you know if it works.
Old 03-10-2004, 11:33 PM   #10
72bigblock4wd
I pulled the rear window motor and tried to see if it would run if I contacted the posts on the battery briefly. It didn't want to run, however I don't know if the motor works once it's disengaged from the window mechanism in the tailgate. If you know if another way to check the motor let me know. I do have access to an ohm meter if you know what it should be for this motor.
