timing w/a light
ok call me stupid but i dont know how to tune an engine with a light. ive always just timed it by ear to where it ran the best, but they dont always like to start up at that point. can anyone step by step explain how you do it with an adyustable light.
thanks -kyle
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
Way i do mine is remove the vaccum advance off the distributor and use the air cleaner stud to plug it then put the test lead off the light on the number one spark plug wire
Hook the red and black leads to hot and ground on the battery and depending on where your timing mark is point it at it and set it from 6-10 depending on what kinda engine combo you got i normally start off with 6 and go from there |
20' Daredevil (Ret)
![]() Join Date: May 2003
Yup, what he said, and if it's fighting the starter you have too much advance - 'course, you probably already knew that. Also, make sure your advance is working and not stuck on full advance like mine was after the engine rebuild!
Professional Grade
I gotta get me a new timing light, toasted my old one
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
A good timing light is a must Ive recently got me a snap on Nice light but i cant say it does any better than the sunpro i replaced it with.
