now thats a true COON DOG
![]() Join Date: Nov 2000
Converting from drum to disk
Hey all, I'm getting ready to do brakes on my 68 burb'n this spring and wanted to know if anybody had done one of those 6-lug disk brake conversions to there 67-70? If so what did you think? Did the kit have everything you needed to do the compleat job? Thanks for any feedback. -Brian
current project 67 ![]() 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) ![]() 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
im pretty sure lobo 74 did it. i want to get 6 lug rotors instead of switching to 5 but they are too expensive!!!
70 longbed 496/th400/Ford 9" |
Dinnut- 6 lug rotors expensive? I have seen in classic trucks mag a few different supplyers that sell the whole convertion kits for $239.00.......
I am a Referee of life.
71 the $239.00 is for the brake kit.It doesn't include the spindles for disc.The spindles are another $229.00. You can get them in 2 1/2 lowered or stock.The disc wont bolt to stock drum spindles.There is another kit that consists of just brackets to install disc on the drum spindles but if I remember right it sells for about$149.00.Good luck with your conversion.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Oh, ok I see! I knew that disc's didn't fit on drum spindels but they made it sound that way! Thanks for clearing that up!
well, they were too expensive for me right now...... plus shipping would be expensive as a mother
Im converting my son's 70 GMC to disc. I went out and bought a K-member from rotor to rotor...including the calipers, the proportioning valve, lines...ect. My plans are to swap the whole thing out, THEN get 6-lug rotors, being we'd allready bought wheels. This way I can redo the ball joints, control arm bushings, ect...paint the assembly, and then swap out the whole piece. Im planning on swapping out the manual steering gear in lieu of power while Im at it. Any advise on this subject would be GREATLY appreciated....as I know 1 or 2 of the holes have to be elongated somewhat. Im planning on taking pictures as we go, and I'll be posting them on our website.
Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!" - 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM" - 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL" - 1982 Chev C-10 swb/step 250 I-6 3 spd - - 2001 Chev Silverado LT - |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I am wondering what happen's when the rotor's wear out or something bad happen's to the rotor's do you have to buy a new one from E.C.E. or ?????
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
re brakes
I put in one of the kits from Stainless Steel Brakes last year.
Everything went on ok. The problem was that the kit was shipped with the wrong bolt to hold the backing plate. It rubbed the rotors when I made a turn. This wore grooves in the rotors. I had to make several calls and write letters. They shipped new bolts and rotors and it has worked fine since. EdB |
edb- thats good to know thanks for the info.
frenchblue72- Thants a good question, I'd like to know also. Does anybody else have any input?
