Old 03-07-2004, 11:24 PM   #1
wink_tim
wink_tim's Avatar
Question rear brakes
I was trying to bleed the brakes on my truck and had no pressure at the rear, I was wandering what some of the less obviuos causes for this might be. I just finished converting to a 5 lug front disc brake settup, I installed a new master cylinder but used a proportioning valve off a 72 that worked fine before.Any ideas would be appreciated.
67 SWB
wink_tim is offline   Reply With Quote
Old 03-08-2004, 01:42 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Did you bench bleed the master before you installed it?
Old 03-08-2004, 03:05 AM   #3
jimfulco
Bleeder screw plugged?
jimfulco is offline   Reply With Quote
