71 and 72 c20 rotors
are the 71 and 72 c20 dics rotors the same? will they use the same caliper? bearings? etc. do the other brake parts from those years interchange?
beater 65 gmc at the moment |
Napaonline shows same part numbers for '71 and '72 rotors, caliper part no's. aren't the same though.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() Last edited by Sweet72; 03-08-2004 at 12:53 AM. |
Keepin an eye out
Check carefully, I know theyre different for 71 & 72 c-10's.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
