Garage Queen Material
distritbutor wont fit all the way down.
i'm trying to install my distributor but it wont fit flush with the intake. its about a 1/4" or a little more off. the rotor is pointing towards the #1 terminal and i beleve that the engine is on TDC, and i have my timing preset to 11 degrees. i had to turn the oil pump a bunch of times just to get the dizzy down that far
Mudslides 'r my specialty
Do you have the distributor gear on upside down? That will make it sit up a bit.
Don't laugh, it happens.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
it better not be, msd sent it to me that way if it is
Professional Grade
Hmm, if you are sure that your oil pump shaft is aligned properly, then there is a possiblility that maybe your oil pump shaft isn't down all the way or something. With me, all it took was a quick rotating of the shaft and it slid right down.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
does it matter that my block is zero decked?
with the dizzy in the engine as far as it will go right now, the rotor WILL turn when i turn the engine over by hand
Professional Grade
Yeah, but you want that gap filled...
How much did they take off when they zero decked it?
it was a stock 71' block. i dont know for sure
http://www.jegs.com/cgi-bin/ncommerc...01&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...30&prmenbr=361 am i gonna need soemthing like this? |
Professional Grade
Sounds like you need the second one you posted if you're sure that your oil pump is all the way down and aligned properly.
hmm...
it fits now :/ ![]() ![]() ![]() i just had to keep dicking around with it a lot. now i get to install the rest of my stuff after i go to the dentist!!! |
Professional Grade
I figured as much
#13 |
I seriously don’t think you had that much removed from the deck, or you would have had a lot more problems getting other things to match up.
If you have the dist. In far enough to turn the rotor when you turn the crank over by hand, keep turning and it should drop down onto the oil pump drive shaft with light to no pressure pushing down on the dist. I’m not saying you won’t need shims but .250 is a lot of material If you are using the o-rings on the shaft did you chamfer (sp?) the block were it passes threw in the lifter galley. This could also keep you from getting it to seat if it is hanging on one of the o-rings.
#14 |
Man I need to learn to type faster
#15 |
I have found that sometimes if you bump the engine over with the starter it will fall in to place, other than that it will sometimes only drop in once lined up with the pump gear exactly.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
#16 |
zero decking usualy removes about .02 so there is now way in hell you could get a 1/4 inch gap from that. glad you got it in though. lining the oil pump slot up can be a pain sometimes
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#17 |
not with a big screwdriver its not.
![]() i've run into that problem a few times. when i built my first engine, i had the intake off 3 times because i couldnt get it to seal properly. i put it in once, and it left a gap just like Eric's did. i didnt think much of it, put the clamp on and snugged her down. when i fired it up i heard a *ca chunk* as i cranked it over. ran fine until i shut it off, then apparently the dizzy walked a little bit and threw the timing way off. grabbed the dizzy, and it was as if i hadnt tightened it down at all. i always make sure that they're fully seated now. |
#18 |
ocbaud
Did you need anything else with your msd ie (wiring harness or different clamp for it?) Thanks
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
#19 | |
#20 | |
really really simple to hook up. |
#21 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
