Old 03-08-2004, 06:17 PM   #1
angelsairman
Future Owner
angelsairman's Avatar
Question 2 piece drive shaft question
I have a 71 chevy c10 with the two piece drive shaft. How do i seperate the two as i have to have the front one shortened. Please help my repair manual doesnt say or at least i cant find it.
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 03-08-2004, 07:01 PM   #2
cdowns
cdowns's Avatar
remove the center u-joint and the yoke is held on by a bolt unbolt the yoke and take the carrier bearing off
Old 03-08-2004, 07:26 PM   #3
angelsairman
Future Owner
ok this is going to sound dumb, but how do you remove the center u joint??
Old 03-08-2004, 08:19 PM   #4
oldsub86
Use a press or a large bench vice. There are also things that look like a big C clamp designed for pressing apart U-Joints.
If you have not done it before, look for a friend who has to help you out.
Remember to mark the relationship of the pieces before taking it apart so that you can put it back as it was to avoid vibration issues. I usuallyjust use a can of spray paint and draw a line down one side. Then I know the parts line up on the stripe.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 03-08-2004, 08:38 PM   #5
rage'nrat638
rage'nrat638's Avatar
HEY....HOW DID THAT INSPECTION COVER WORK OUT????
rage'nrat638 is offline   Reply With Quote
Old 03-08-2004, 10:46 PM   #6
angelsairman
Future Owner
RAT... the cover was perfect Thanks!! the pulleys and water pump worked out great too..ill attach a pic of them installed. ...Now back to the question at hand, so basically im going to have to remove the entire driveshaft and bring it to the bench vice, there is no way to just seperate the front from the back with it still under the pickup??
Old 03-10-2004, 02:31 AM   #7
jimfulco
It's easier if you take it out first, & you gotta take it out anyway, right?
jimfulco is offline   Reply With Quote
