wiring in an engine
I need to wire in this 350 to fire the beast. Can aanyone give me some info on what wires go where? It is an 82, 350 with hei and a passenger side alternator. Totally opposite from my inline 6 with points and a drivers side alternator. Now, I am a rookie for wiring, so make it as simple as possible
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Is the engine 1982 or is the truck? This makes a big difference, b/c if you need to do wiring on an 1982 truck I would be lost, but if it goes to one of the 1967-72 I might be able to help.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi 1997 C2500 Ext Cab 5.7 Liter 1955 3/4 ton 1st series w/ 235 straight six Sold it ![]() |
Here is a link to the 67-72 wiring diagrams.
Jim http://www.geocities.com/chevroletc1070/wiringdias.html |
Future Owner
i bought a wiring harness from Brothers to do mine and it was much easier and cleaner and resonably priced, you can also get the hei wires on it to and if you going from int to ext alternator the kit is also available. Just get it for the V8 with the options u currently have, i found it to be pretty self explanatory on what went for what. And its also factory color coded.
Its not the end result that counts most...its the journey along the way that's most rewarding My truck doesn't leak, it just marks it's territory |
if you are just looking to start it run a wire from the battery put a split in it and on one of the splits run it to the distributer and put a starter switch in the other one and run it down to the starter, hook up your cables and vwoila, thats what i did as a tempory thing on my flat bed to keep the engine from just sitting
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
heres a crude diagram for you
Thanks for the link Jim. Oh it's an 82 engine in a 72
