Old 03-09-2004, 09:59 AM   #1
Brewski*
Brewski*'s Avatar
New lift installed=>understearing to the right, overstearing to the left. Any help?
Just got my Skyjacker 4" lift installed>>>>Do you have to do alot of adjusting on the adjustable end link? My truck is understearing to the right, overstearing to the left and the stearing wheel is 1/4 out of turn to the left so the wheel is sideways arms pointing up and down instead of left and right.
The drop stearing arm appears to be about 1.5" longer than stock I called Skyjacker and they said to adjust the end link. Is this correct? I want to make sure it is right before getting the front end aligned again.
Brewski* is offline   Reply With Quote
Old 03-09-2004, 10:07 AM   #2
Dean
Dean's Avatar
I sent you a PM. If you keep you adjustments straight you won't need an alignment. That is unless you needed one to start with.
Dean is offline   Reply With Quote
Old 03-09-2004, 01:56 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Yep the pitman arm should be pointing straight out the side, with the wheels straight ahead.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-09-2004, 02:11 PM   #4
Brewski*
Brewski*'s Avatar
Is there also a way to adjust the pitman arm? I have the steering wheel centered using the adjustable drag link but still does not turn well to the right and will overturn to the left.
I think I need a shorter steering arm but SkyJacker does not offer one. I may go with one from another manufacturer. Do you know of one that is the exact lenght of the stock one only taller?
Old 03-09-2004, 02:23 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Even easier: With tires pointing straight ahead, and with your oversteering left and under steering right adjust the drag link to make the steering wheel turn left one complete turn and center the steering wheel.
