Post Whore
![]() Join Date: Feb 2000
My dash harness wiring is in good enough shape that I am not going to replace it while it is out but looks like the terminals that hold fuses and spade terminal ends could use a cleaning.
What is the best way to clean them? Is there a solution I shoud use or just a small wire brush?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Tasty Cakes!
You could probably use a can of electrical contact cleaner.
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
a coulpe of mine where rusty.....
i had to get out the old pocket knife...and scrape it off ![]() |
![]() Join Date: Feb 2002
Blue Shower is an electronic tech spray. It works good, doesn't damage plastics or wiring, evaporates quickly, and probaby kills the ozone. (JK - they changed the formula). Or you can use the old school q-tips and alcohol method. An ignition or hobby file [1/4" wide blade] is good for cleaning up copper/brass contacts. Clear silicon ignition grease (dielectric lube) is good to smear into connections to prevent re-corrosion after you've cleaned it, if you live in a corrosive or damp climate.
Use a brass "Marine tooth brush" to remove tarnish/corrosion. clean with isopropyl in a spray bottle and acid brush, then dry with compressed air or just air dry. Using any type of corrosive cleaner may deteriorate the wire over time. Treat the cleaned contacts with a corrosion inhibitor, wd-40 and dry again w/air.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
If just dirty, use a q-tip with wd40 or any other mild cleaning agent. If you see rust, better to leave alone as any abrasive cleaner(wire brush, file, penknife etc.) that will clean rust will also remove the coating on the connectors that hold the fuse's. I have that problem on one of mine and it looks kaka.
In reality you can't easily get to the inner part of the fuse holders to clean them with any tool I've ever seen. I used Qtips to remove any loose crap and then some dielectric grease to minimize the effects of condensation and the water leaking design the trucks came with from GM!! ![]() |
Post Whore
Thanks guys. This will help me!
The WD 40
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
