Old 03-09-2004, 11:32 PM   #1
ScottH
ScottH's Avatar
Question converting from manual to TH400
I have a 68 C10 that had a sbc with a four speed before I got it. Not sure what the truck was originally. I plan on installing a 402 with a TH400. My question is will I need to install a high hump center section in the floor?
Any info or suggestions are appreciated.
Thanks.
Scott
ScottH is offline   Reply With Quote
Old 03-09-2004, 11:39 PM   #2
Vince M
Vince M's Avatar
Can't help with the big block but my TH400 behind a small block fits in with a small hump.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 03-10-2004, 01:09 AM   #3
67_SS396
I have a 408 BB in my '67 and am in the middle of installing a TH400. It clears just fine and I have the small hump cab. I even used later model engine mounts that sit the engine slightly higher than the period correct mounts. All I'm waiting on now is my converter from Torco and shortening the driveshaft, then she'll be back on the road.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 03-10-2004, 01:54 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My truck is also a low hump conversion to big block and TH400. It's close, but it clears. If your cab mounts are saggy though, the cab will rub the transmission. New mounts will raise the cab up enough to relieve the problem.
