Old 03-10-2004, 12:28 AM   #1
74Pumpkin
Insert witty comment here
74Pumpkin's Avatar
Off Topic Question. PT cruiser
I'm sure there is a site out there for this question But I don't belong to any of them. So I hope no one is offended that I ask here.
Wife's car.. 2002 PT cruiser. Has some noise when brakeing. I checked the fronts and there ok. I went to check the back set,= drums. I could not for the life of me get them off. My question. Does anyone know if there is a trick to this type?or an I missing something simple? I have taken off my 74 rear drums many times so I'm not totaly stupid.
Any help would be nice!
So many trucks, So little time!
74Pumpkin is offline   Reply With Quote
Old 03-10-2004, 01:10 AM   #2
shavn80
I don't think they're any different than other drums?
did you remove the little spring nuts they install from the factory that hold the drum on? if not, get a hammer!
shavn80 is offline   Reply With Quote
Old 03-10-2004, 01:13 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
It could be a couple of things. First one is simple but often overlooked. Does it have the retainer locks pushed on any of the lug bolts? Most vehicle have a push on retainer on a couple of the lug bolts that hold the drum in place on the assembly line.
Next, and more probobal is the shoes are extended out far enough that they are catching on the drum. If it acts like it wants to start coming off, but won't this may be the problem. Try backing the pads off a bit, and see if this helps...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-10-2004, 11:45 AM   #4
74Pumpkin
74Pumpkin's Avatar
Thanks Guys. I did take the clips off. I'll have to see if I can back the shoes off. What a PITA.
Old 03-10-2004, 11:54 AM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I don't want to insult you, but make sure the parking brake is off. Not that I have ever made that mistake before, of course! Okay, well maybe once...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-10-2004, 11:59 AM   #6
Russell
Professional Grade
Russell's Avatar
Slonaker
You ain't the only one, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
