Old 03-10-2004, 12:36 AM   #1
76bonanza
76bonanza's Avatar
one more carb question
I have a holley with a accelerator pump it looks to be adjustable?
How do you adjust it.
The previous owner was not to keen on setting anything as everything was jacked up.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-10-2004, 10:30 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I'm guessing you are talking about the adjustment bolt on the end of the pump arm. It is used to set the maximum pump shot. You can increase or decrease the volume of the shot by adjusting the screw. To truely adjust the pump you must replace or flip the pump discharge cam, which is a small plastic piece on the throttle shaft. A lever from the pump linkage rides on this cam. You can also replace the discharge nozzle assembly to increase the orfice (sp?) size. Do a search on the web for tuning instructions and you should find all the explanations you need. Good luck.
NeCrOmAnCeR is offline   Reply With Quote
