03-10-2004, 12:48 AM | #1 |
Life, Be In It.....
Got My New One Piece Drive Shaft
I ordered it from Denny's Drive Shaft, about $300.00. I will put it in tomorrow. Then Order some stainless brake lines.
03-10-2004, 12:52 AM | #2 |
looks good
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
03-10-2004, 01:34 AM | #3 |
RUNN over AGAIN!!!
Nauice!!!!!!!!!!
67-72 TRUCKS ROCK 70 SWB shaved and a 72 front clip.and a poly tank. Peep mirrors and a BIG BLOCK 468 in the making. XNXNXNXNXNXNXNXNXNXNX ,/. EMAIL ME HERE!, Dont pm me please ,/. |
03-10-2004, 01:43 AM | #4 |
Future Owner
whats it going in?? Is it possible to convert a 2 piece driveshaft on a long bed 2wd to a one piece??
Its not the end result that counts most...its the journey along the way that's most rewarding My truck doesn't leak, it just marks it's territory |
03-10-2004, 01:43 AM | #5 |
Young Gun wth Fast Inline
Long or short box, i want to do this to my truck also.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
03-10-2004, 01:47 AM | #6 |
RUNN over AGAIN!!!
I meant jugernot's AVATAR!!!!!!!!!!
03-10-2004, 01:49 AM | #7 |
Life, Be In It.....
I am putting it in a 68 short step side. There is a maxium length for a one piece drive shaft, but I can't remember what it is. I think a one piece for a long bed is too long. I no expert though.
There is a pic of the truck. |
03-10-2004, 03:01 AM | #8 |
Do they give a warranty or horsepower gaurantee (sp) ?
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
03-10-2004, 05:56 AM | #9 |
The Sauz
Correct me if I'm wrong but don't four by's and 73 up long boxes have a single shaft out back, I don't think length is a problem.
68 lwb 2wd (spread between 3 garages) 72 Burb - Flat Deck 92 Yukon 3" lift - 33's - the new bush pig 01 Sierra - Daily Driver (for now) |
03-10-2004, 06:39 AM | #10 |
Life is a gamble
looks nice and shiny
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson |
03-10-2004, 08:10 AM | #11 |
shaft
That looks great. It is stainless I take it. What is the lengeth of it U-joint to u-joint? and what are you using for a tranny? Is your engine in the forward v8 position?
I need to make one. save me the measuring trouble. Thanks, Peter |
03-10-2004, 12:22 PM | #12 |
Sixty8,
My 72 Long Bed 4X4 has a one pc drive shaft too. Remember that a 4x4 has a transfer case, that ends up making the rear drive shaft shorter.
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
03-10-2004, 12:33 PM | #13 |
Guys,I think the reason for the two piece shaft was for the trailing arm trucks.I own two 85'chevy 4x4s and 1 2wd short bed 83' and they all have one piece shafts. I think youlll be alright going with a one piece shaft in your long bed truck. The only place to check is where the factory put the crossmember for the trailing arms, if you get to much wait on the back it might cause interfernce with the shaft and the cross member.Unless you have leave springs and the trailing arm crossmember is not in there. Then you should be ok
03-10-2004, 12:42 PM | #14 | |
Progress = 0%
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
03-10-2004, 01:44 PM | #15 |
is it aluminum or stainless? very nice, good price too.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
03-10-2004, 04:48 PM | #16 |
Life, Be In It.....
HYPERMAN
It is aluminum, 55 inch long. I have a 327 .40 over, 350 tranny. Its rated for horse power well over what my 327 will be putting out.
03-10-2004, 04:58 PM | #17 |
Life, Be In It.....
I would agree with Slammed67, you should take measurements of you own. There are to many varibles. IE differential, tranny, etc. I will say the guys at Denny's Drive shaft are very professional and are happy to expalain this to someone who lack the knowledge, as I did.
http://www.dennysdriveshaft.com/index.html |
03-10-2004, 09:51 PM | #18 |
My '72 w/ leaf rear has a 2-piece shaft and I don't have trailing arms....So, now what is the reason for them? Balance? Rigidity?
03-10-2004, 10:51 PM | #19 |
i have 1 pice in my lwb 71
03-11-2004, 12:05 AM | #20 |
my dad had a one piece in a LWB about 10-15 yrs ago-the shaft came from a ford truck and he got u-joints to adapt ford/chevy frrom napa -but at the stock ride height he had to cut the bottomout of the x member the DS goes through-I think with a lowered truck that wouldn't have been required-or the cut x member could be reinforced
1972 LWB 4x4 1970 LWB 2wd 1971 chevelle 1972 datsun PL-521/nissan |
03-11-2004, 02:20 AM | #21 |
69 1/2six pack bee,
im not claiming to know every thing that chevrolet and gmc did i wasnt on the design team but your reply that balance and rigidty might be the answer. all i know is on the few 67-72 trucks ive worked on they had trailing arms and the two piece shaft carrier bearing was located at the same cross-member as the arms thats all! I aint on here to start problems just tring to help out |
