Future Owner
ok guys..here i am with another one of my questions, i have these two connectors on the drivers side of the firewall(top right in picture). They both mostly run into one harness and all but one wire has been cut. I dont know if it matters but it had been converted to Int Reg Alt. Can anyone tell me what these are and what the control so i can fix this mess??? I tried to find them on the wiring diagram but got to lost. Any help would be appreciated....
Its not the end result that counts most...its the journey along the way that's most rewarding My truck doesn't leak, it just marks it's territory |
Future Owner
i guess i should have mentioned that this is a 71 C10 half ton 2wd with a v8........
Young Gun wth Fast Inline
never seen them before on any other truck ive had What it goto?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
Future Owner
i wish it knew what it went to all the wires have been cut but one green one with a spade connector on the end.
huh ???
Those are for the trans spark control BS. My 71 blazer had them and so did 72Blazerman's I didn't have to worry with them on my truck as I used it for parts, but on Doug's truck whin I rebuilt his wiring harness I deleated them...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Future Owner
so basically i shouldnt worry about them just cap off the cut ends?? What funtion did the trans aprak control serve, ive already dropped in a 350 and swapped the 3 on the tree for a automatic.. So i shouldnt need them..correct?? But just for gee whiz information just wondering what they did do.
huh ???
You should be able to follow the wires up into the plastic wiring gutter on the fire wall and there should be a dark brown wire with a single blade plug where it connects to the rest of the harness.. I don't remember the whole thinking by GM on it but basicly I think it would keep the vaccume advance retarded until the trans was in high gear...
Chuck
It's a smog device that cuts the vacuum advance out except in high gear. TCS=transmission-controlled-spark
Too many is never enough!
relays
Basically what the other guys said. The wiring goes to another temp. sending unit on the passenger side of the block and to a vacuum solenoid placed inline between the vacuum advance canister and the carb. Also runs to a idle control switch on the carb. The entire harness is self sustained and can be removed without effecting your main harness. Just remove the relays from the firewall and pull the harness out of the gutter.
Basically it prevented any vacuum advance until the motor heated up to proper operating temperature. Early emissions technology. Unless you want to keep everything stock, tearing it out is the norm.
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
They are quite correct. Further, if any of the parts (especially the vacuum switch) is missing, they are impossible to replace today.
If you still have the parts, you may want to label and hold onto them -- someone who wants to return to completely original is sure to ask for them someday. Brian |
