Old 03-10-2004, 12:57 PM   #1
dubie
dubie's Avatar
help with aligning hood
After installing the hood hinges and bolting on the hood, it won't close. We adjusted it a few times but just doesn't seem like it wants to align properly. Do you guys have any tips I should try?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-10-2004, 01:02 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Assuming the clip and cab are bolted to the frame and tightened down, I would loosen everything up so that you can adjust alignment of more than just the hood. It sounds to me that your clip may not be quite "square" on the frame. I don't have any magic bullets for you as panel alignment is somewhat of an "art".
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-10-2004, 01:08 PM   #3
dubie
dubie's Avatar
yeah, I figured it's because the front clip isn't bolted down, it's just sitting on the frame right now. I will wait to align it until It's all fastened down and shimmed properly.
Old 03-10-2004, 01:14 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
You really have to attack it as a whole. An adjustment in one area affects another. It can be frustrating, which is why you see so few trucks with 100% perfect lines. It takes an expert. Take comfort in the fact that when new, the panels were nowhere near perfect either.
Old 03-10-2004, 01:24 PM   #5
dubie
dubie's Avatar
I found that out when I replaced one of my cab corners and found factory body filler on the B pillar
Old 03-10-2004, 07:39 PM   #6
72MARIO
72MARIO's Avatar
Hey !
Make sure that the big bolt that goes thru the innner fender to the cab is loose. Make sure you shim it to the cab dont squeese the gap between the inner fender and the cab frame closed. It will mess up your lines like crazy.
Good luck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
