Old 03-10-2004, 01:06 PM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
Urgent Help with Part number
Can anybody give me a GM part number for a standard rubber transmission mount for a 67 with a 350/TH350. My UK parts supplier seem to be having trouble identifying which part I need. I made the mistake (despite advice from one or two board members, I know, I know!) of putting in an Energy Suspension poly mount and it transmits so much noise and vibration it's making my feet go numb! I'm hoping it will help them find the right one if I can give them a GM part number.
I have attached a couple of pics of the original mount, it's a bit past it's best.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 03-10-2004, 01:09 PM   #2
Lippyp
English Chevy Owner
Lippyp's Avatar
The little tag that projects from the back of the mount wasn't hooked up to anything.
Phil
'67 C10 long fleet.
Old 03-10-2004, 01:14 PM   #3
Lippyp
English Chevy Owner
Lippyp's Avatar
last one
Phil
'67 C10 long fleet.
Old 03-10-2004, 02:57 PM   #4
Maximum Overdrive
December 21, 2012
Not sure of what the GM part # might be but you should be able to track a number down from Parts America website. They list pictures of the parts. Here is just one they show for 67.
Parts America
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 03-11-2004, 07:32 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
Can't use that site as I don't have a zip code. I really wanted a GM part no as they may ahe a cross reference book. is there more than one mount for a TH350 equipped truck or were they all the same 67-72....Help!
Phil
'67 C10 long fleet.
Old 03-11-2004, 08:56 AM   #6
jamis
F.A.S.T. president
jamis's Avatar
Here is the info from that web site. The picture it shows is not the same as yours, but it could be a generic picture. I looked at one of the parts book at my shop and I dont understand what they mean by m38-3at, m40-3at. I think the M points t manual series and AT to automatic, but it really makes no sense the diffrent part numbers for the same aplication. If you know what those numbers are let me know and I will lookat the parts book again
Pic Description Availability * Price Add
Anchor 2282
Engine Mount: Frt.; LH & RH
1 Year Limited Warranty Ships in 1 day
Weight: 2.7 lbs.
$7.79
Anchor 2378
Transmission Mount: (Incl. M38-3AT); (Incl. MT)
Weight: 2.5 lbs.
$6.49
Anchor 2268
Transmission Mount: M40-3AT
Weight: 0.5 lbs.
$7.79
jamis is offline   Reply With Quote
Old 03-11-2004, 10:11 AM   #7
Edmond
Edmond's Avatar
Hey Lippyp, what I usually do in these cases is put in the Zip code of that $hitty TV series 90210
Works all the time
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 03-11-2004, 11:40 AM   #8
Lippyp
English Chevy Owner
Lippyp's Avatar
Thanks Edmond, never thought of that! (or watched it!!)
Phil
'67 C10 long fleet.
Old 03-11-2004, 12:27 PM   #9
COBALT
COBALT's Avatar
Energy Suspension makes a poly replacement for those. I took out my rotted mount for my TH400 and got one of those. Works great, and the blue looks better than the soggy rotten black...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 03-11-2004, 01:27 PM   #10
71Chev
71Chev's Avatar
The dicontinued GM part # for the rubber th350 transmission mount is 334528. If I find a new number for it, I will post it.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 03-13-2004, 07:04 AM   #11
Lippyp
English Chevy Owner
Lippyp's Avatar
Well, my specialist supplier came up with a part, just received it and it's an Anchor 2378 as above, so I'm guessing it's the right one, thanks for the help everyone.
Phil
'67 C10 long fleet.
