Old 03-10-2004, 02:27 PM   #1
angelsairman
Future Owner
angelsairman's Avatar
Question Spark Plug Wrong???
installed some NGK spark plugs on my 350. When i installed my new ACCEL wires with straight boots it feels like it is loose on the spark plug like the connector part on the spark plug is to small or something...are there diffrent size spark plug connectors on wires or on the spark plug itself. I havent stried to start it yet or anything i was just curious if this was common??
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 03-10-2004, 02:56 PM   #2
rodnok1
rodnok1's Avatar
all the terminal ende are the same on spark plugs. Either the end is loose(common) it will wiggle or you don't have them all the way on. Some are a real pain in the butt to get snapped on, my accel wires are the same way, difficult to get on all the way.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 03-10-2004, 06:46 PM   #3
angelsairman
Future Owner
thanks for the info.......
