Old 03-10-2004, 03:35 PM   #1
Terry Peerson
Under-Hood Fuses
Hi,
Can anyone tell me how to get to the two fuses that make the ammeter work? I found some weird looking connectors up by the radiator support. I'm not even sure that they are the fuse holders. I tried twisting them and pulling on them but they don't want to cooperate, and I don't want to break them or pull the wires apart. So, I didn't get too rough with them.
Thanks,
T
Terry Peerson is offline   Reply With Quote
Old 03-10-2004, 03:43 PM   #2
busterwivell
They should come apart. Mine were so corroded, I replaced them with new ones from the parts store. Easy to find at any parts store.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-10-2004, 04:04 PM   #3
71-longbed
Its Magically Delicious
71-longbed's Avatar
mine were tough to get part as well ... once mine finally broke free they made a loud "POP" of vacuum .... maybe alittle oil might help loosin' them up .... they hold 4 amp fuses in case you didnt already know
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 03-10-2004, 04:56 PM   #4
Terry Peerson
OK But, do you just pull them apart or do you twist them?
Thanks,
T
Old 03-10-2004, 05:00 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Thanks,
T
They should pull apart as they are not threaded or otherwise interlocked. You may have to twist them to free the two pieces but there is no secret combination to separatijng them.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-10-2004, 05:53 PM   #6
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
After I got my first one apart, it was pretty ugly looking inside. I just cut both of them out and replaced them with new fuse holders. In fact, I recommend doing that because then you will have the same length fuses as you do for everything else. The fuse holders for the ammeter are the really short ones.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 03-10-2004, 05:57 PM   #7
smokekiki
Mike
smokekiki's Avatar
I used a pair of needle nose pliers to squeeze the middle to break the fuse.Once the fuse was broke,it came apart and then I could dig the ends out.a little electical grease to put it back together.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 03-11-2004, 08:50 AM   #8
Terry Peerson
Thanks! I'll try to get it done tonight.
T
