Just got done tuneing carb
got vac guage and tuned carb, 12 deg advance, idle about 700 holding about 21hg on guage has a slight drop of about 1/2hg every now and then should I worry about it?
Also I have my dist on ported vac and lots of people say I should run it on full vac when I do it pulls it into advance at idle is that not bad? Just dont want to kill anything and I dont know how worn dist. is will be getting a new one soon(old one is squeeking really bad). Thanks
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Dist should be on ported vacuum.
Edit: Unless you have that funny looking thing that it goes into & then goes out of there to the dist. Then I'm not sure. My 70 has a little "canister" that hooks up to the carb & out of that there are two lines, one of which goes to the dist. Last edited by Deltaskier; 03-10-2004 at 05:55 PM. |
5-7 dropped 87 CC Dually
Wow thats alot of vacuum. I'm used to 8-9.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
TTT
You will start a heated debate asking ported or not-ported. The intermitent drop in vacuume could be caused by alot of things, misfires, sticking valves etc... 21 in of mercury is really good, I only get around 10. Does it seem to idle any better?
Smooth really smooth I only have stock cam so as I understand it normal is between 18-22.
Sounds about right.
Its Magically Delicious
Deltaskier... i have the same setup ...ece soleniod i believe is whats its called... i always wondered if i could bypass it ....anyone done this on a quad 4mv?
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
