Old 03-10-2004, 10:13 PM   #1
ocbaud
Garage Queen Material
messed up coil wire???
why are the connectors poking out of the boots? i ordered it to hook my blaster2 coil up to my probillet dizzy
ocbaud is offline   Reply With Quote
Old 03-10-2004, 10:26 PM   #2
rage'nrat638
rage'nrat638's Avatar
SO THEY GO ALL THE WAY DOWN INSIDE THE CAP/COIL....
MAKE SURE TO USE SOME DIELECTRIC GREASE ON THESE BABYS..
FOR SURE ON THE PULG END......
MAKES THEM PULL OFF LATER WITH EASE....
rage'nrat638 is offline   Reply With Quote
Old 03-10-2004, 10:36 PM   #3
ocbaud
i can understand the coil part, but it needs to be like a normal plug wire on one end, so that it will fit on my dizzy
Old 03-11-2004, 12:27 AM   #4
ocbaud
the connector on the left is supposed to be like that. it fits into the coil perfect like that. the connector on the right, needs to be like a normal plug wire, with the connector inside of the boot.
Old 03-11-2004, 12:38 AM   #5
Russell
Professional Grade
Russell's Avatar
Just stick it on, and slide the boot down, it'll work, my sister's toyota was the same way
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-11-2004, 12:41 AM   #6
ocbaud
that wont work.
Old 03-11-2004, 12:43 AM   #7
shavn80
the boot should just slide down...
shavn80 is offline   Reply With Quote
Old 03-11-2004, 12:48 AM   #8
ocbaud
the connector is bent and shaped to the boot.
Old 03-11-2004, 09:33 AM   #9
Blue Beard
Blue Beard's Avatar
Take them back and talk with the parts guy...
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-11-2004, 09:50 AM   #10
ocbaud
ordered from jegs
Old 03-11-2004, 09:52 AM   #11
ocbaud
http://www.jegs.com/cgi-bin/ncommerc...77&prmenbr=361
121-84049
thats the one i ordered
Old 03-11-2004, 09:53 AM   #12
ocbaud
you know what the one i have looks like? it looks like they have the connectors on backwards
