[Pic] Looks like I can run 5" drop with 28's up front??
This is how my truck sat stock, with 32x11½ 15's under it. From this picture, it looks like with 28's, I could easily run 5" of drop.
you can
i talked to sport truck direct (wich is local) and they said that all their kits are made for the stock tire size and that is about 29" tall i believe even if the tire tucks alittle bit the truck will still turn
Billy Just start hackin away? |
yeah i think 235 75 15 is about 28.88 wich is pretty much 29" tall
have fun rubbing your tires all over your inner fenders, cutting your tires up and damaging your fender lips.............
i have 27" on mine and they still occasionaly rub the inners on a big bump. of course don't mind me, i've only had 4 different size tires on my truck...............and sport truck direct if full of crap if they told you you could run stock size. when i first dropped mine i had 235/75/15's on it and you couldn't hit a 1 inch dip in the road with out them slamming into the inner fenders.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
Professional Grade
Wow, it looks like a real truck with them tires on, lol! Its amazing what swapping wheels will do for a vehicle...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
low 84
are you 27s in the fender or is there a gap between the lip and the tire are you running stock rims it could depend on the offset and all. dont get me wrong i dont want any hard fellings.
#7 | |
looks good
