Old 03-11-2004, 05:14 AM   #1
Edmond
Edmond's Avatar
Driverside door window question
I need some advice.
My driverside door windowglass came lose from the metal bracket.
How is the glass fitted in the bracket. Is it glued in?
Do I need something extra?
Thanks in advance!
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 03-11-2004, 09:40 AM   #2
JimKshortstep4x4
Talking
The rubber in the channel holds the window in place. It is like a press fit. If the sash and rubber are still good, you can glue the glass in using an adhesive, like 3M's Trim adhesive. It works good and lasts for a long time, (I have never had one loosen when glued).
Jim
Old 03-11-2004, 10:06 AM   #3
Edmond
Edmond's Avatar
Aha, so that used to be rubber? Well it was rock hard, and pieces broke of very easy.
Will make a new rubber piece and glue it in.
Thanks JimKshortstep4x4
Cya,
Edmond
The Netherlands
Old 03-11-2004, 12:19 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Ive heard of guys take duct tape and put on the bottom of glass when the rubber is gone and press into metal channel and cut with a razor all that sticks out
sneakysnake is offline   Reply With Quote
