Old 03-11-2004, 10:54 AM   #1
dubie
dubie's Avatar
radiator question
with switching from an inline to a 350, do I need to change my rad? It has the stock 2 or 3 core in it. It doesn't get deathy hot up here like it does in some parts, plus I will be installing an electric fan set up. So do I need a 4 core? ALso, are the hose diameters different from the 2 core to a 4 core?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-11-2004, 11:05 AM   #2
bpmcgee
bpmcgee's Avatar
Dubie,
My '71 blazer with a 350, manual, and no a/c would have come from the factory with a 2 core. Auto trans or A/C would have been a 3 core, and BOTH would have been a 4 core.
And no, the hoses are identical.
Brian
bpmcgee is offline   Reply With Quote
Old 03-11-2004, 11:36 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
No problem with the 2 core. If you opt for a 3 or 4 core, then you need to change the top and bottom mounting pads and brackets.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-11-2004, 11:43 AM   #4
Sweet72
Sweet72's Avatar
I don't mean to steal your thread dubie, but are there only two sizes of rad mount brackets/pads? My truck has a two core (not sure if it's had a new core soldered in) and the new pads I bought for the 2 core are too small, tanks won't fit inside the pad saddles! ???? thanks fellas
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 03-11-2004, 12:07 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
There is one problem I can think of when using the I6/manual radiator with a V8. The problem is not cooling capacity (in your climate) but the width of the radiator itself. If it's the stock I6/manual radiator, it is not as wide as the V8 or I6/auto radiator. Consequently the hold down brackets are not spaced as far apart as on a v8 (notice the 2 sets of mounting holes on your rad support). If you go with what you have (again assuming its the stock I6 unit), you won't be able to bolt on the V8 fan shroud without some "backyard engineering".
I guess I vote on getting the right radiator for the application now, while you have it all apart.
As for the other qestion, there may be a difference in radiator core width between the 3 spplications - I6, V8 manual/no A/C (2 or 3 core), and the 4 core unit installed in V8/A/C/auto rigs.
Old 03-11-2004, 12:17 PM   #6
dubie
dubie's Avatar
Thats the reason I am going with an electric fan Jeff But I'm glad you brought that up. good point!!
Old 03-11-2004, 12:26 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
Now you have to upgrade your electrical. (Oh what a tangled web we weave...:p )
My I6 to smallblock with 3 speed manual project just fell together almost like it was designed that way, what's your problem?
Old 03-11-2004, 12:30 PM   #8
dubie
dubie's Avatar
yeah, I will have to do some more wiring I am going to stick with the clutch fan until the break in is done, but after that it's getting the 14" electric fan. I have heard that a Van shroud or a big block shroud would work for my application. Maybe I'll just do that and leave it......................who knows with this project anymore
Old 03-11-2004, 04:32 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Tim, your engein is in the inline position, right?
With the exceoption of what was said about the width, there are a couple solutions for the fan shroud.
Crazy longhorn (anyone know where he's been??) said that you can get a long water pump, and that should place the fan pretty much right in the correct spot of the stock 2 wheel drive small block shroud.
There is also the 'stock' way to do it, even with teh inline positioning, you can just get a small block 4X4 shroud. Since the 4X4 placed all engines back there, the fan will fit just like 'stock' with the 67 - 72 style short water pump.
Personally, i would go one of those routes, and then have the electric fan as a back up or aux fan...that's mostly becouse I don't trust the electric ones...I've seen WAY too many cars that came with them blow head gaskets becouse the fan died and the driver had no idea.
Old 03-11-2004, 05:13 PM   #10
dubie
dubie's Avatar
Thanks for the tips Andy. My engine is from an 82 and came with the 9" long water pump, so the stock clutch fan does sit forward quite a bit. I am going to do the break in with the clutch fan and may end up staying with it just so I don't have to mess with more wiring. I just wanna get it done and running right now
Old 03-11-2004, 05:43 PM   #11
gr8scott51
gr8scott51's Avatar
My 350 is in the I6 position with a long waterpump and small block shroud. I added a 4 inch wide strip of aluminum to the shroud lip to fully enclose the blades. Oh yeah, I put in a 4 core radiator because it overheated so bad during the cam break in, but I think the stock one would have been fine after that.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 03-11-2004, 06:05 PM   #12
Lobo'74
Lobo'74's Avatar
Change it
I had a new (one year old) I6 size radiator in my hopped up 350 Truck. Always ran HOT. Was about 210 or so at stop lights. In haevy traffic got so hot I had to shut it off. Bought a 4 core HD (V8) radiator off of E-bay. Put it on and a shroud and once the thermostat opens up Truck runs 190 (late summer/early fall) to 160 (winter). Only problem with my cooling system now is the fan blade sit about an inch or two away from the shroud. I think I need a longer nose on the water pump. The one on there now is a short one.
I'll be getting rid of my "new" old I6 radiator on the parts board in the next week or so.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 03-11-2004, 06:26 PM   #13
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Get a 3 or 4 core radiator. There is probably years and years worth crap in the inline 6 radiator. And I agree it will always run hot with the I6 radiator.
67Fleetsidedream is offline   Reply With Quote
Old 03-11-2004, 06:34 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Mine always ran right at 180 degrees with a 6 cylinder radiator and a small block with no fan shroud at all, except that little 6 cylinder sheetmetal piece on top. This is 3.73 gears and running it hard in Texas heat.
Look at it this way, if it works, you've saved money, if it overheats, then you can drop the cash on a bigger unit.
Old 03-11-2004, 09:00 PM   #15
slam33
slam33's Avatar
I would just go to a 4 core, I got one from US Rad for $125 and they brought it to me. I got the mounts and pads from LMC. The thing runs cool as can be.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 03-12-2004, 09:27 PM   #16
Andy4639
Old member
Andy4639's Avatar
Thumbs up Radiator and shroud
The radiator is good insurance for the motor to run cool. The clamps are different for the 4 core. I just had mine cleaned and fixed where it was leaking on the inlet nozzel.
The shroud should help a lot on the cold air flowing through the fins to keep the air directed to the motor.
The blades shouldn't be all the way in the shroud. The best position is about 3/4 of it inside the shroud. This is for maz cooling effect.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
