Old 03-11-2004, 08:23 PM   #1
FirstGen
Just Don't Stop!
FirstGen's Avatar
Well Sh*t
Looks like I'm going to need a new motor for my truck. Mechanic says leak down test shows low compression in 3 cyclinders with 80% of it as result of blow by the rings
Will probably look to replace the transmission also while I'm at it.
I'd like to find a 327/350/383/400 SBC and a 700r4 to put in my truck. Anybody have any opinions on shops in the Dallas area or mail order to reccomend? Also open to board members that might be selling a new or barely used motor and or transmission.
Thanks guys. Bad bad day...
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 03-11-2004, 08:32 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Just rebuild it. It would cost you less in the long run. You can gat a rebuild kit for $150.00. Plus you can add some HP goodies to it and make it really run. If I lived closer to Dallas I would rebuild it for you.
67Fleetsidedream is offline   Reply With Quote
Old 03-11-2004, 08:39 PM   #3
67_SS396
If you want to go for a rebuild, I highly suggest Kim Barr Racing Engines in Garland, he does top notch work. That or you could go with a GM crate engine with an outstanding warranty.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 03-11-2004, 08:57 PM   #4
FirstGen
Just Don't Stop!
FirstGen's Avatar
Yeah, I had a buddy that used Kim Barr you are right about his stuff. I would rebuild it but I'd rather get something with more cubes since it is only a 307. I really like to go no smaller than a 350...
TT LSA/6L90e/9"
Old 03-11-2004, 11:36 PM   #5
angelsairman
Future Owner
angelsairman's Avatar
definatly go with the 350, cheapest motor to rebuild....
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 03-11-2004, 11:37 PM   #6
angelsairman
Future Owner
ohhh and PAW sells some decent long and short block kits.....
Old 03-12-2004, 01:01 AM   #7
Joey-D
City's Articulation Ramp
Joey-D's Avatar
Check out Larry's Performance Shop 323-722-8865
www.larrysperformance.com
These guys quoted me a 383 shortblock with TRW forged piston and 10.1 compression fully assembled, balanced and blueprinted shipped to my work for $1400 and something. That is amazing! The 350 block I had was going to be $1500 for machine work (.30 over, decked, and cleared for the 400 crank) plus another $800-900 for a rotating assembly. Plus I would have had to put it together. Not exactly what I wanted to do for my first motor build was 383 and have to double check and triple check the clearance and grind down the block when I am just an amateur, but I wanted the stroker. They do all that work for you. I know that having them assemble it takes the fun out of the build, but hell no you know its done right. They do this day in, day out. I haven't made it to that point yet, so can't tell you if its a good motor, but you can't beat the price.
Also someone on this site has a new 571 Gm crate motor for sale. Yes I said 571. Its the 12.1 compression 720 hp 650 ft lb? motor. Only $15,000. But just remember, it has GM's warranty!!!!!!!!!!
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
Old 03-12-2004, 01:10 AM   #8
FirstGen
Just Don't Stop!
FirstGen's Avatar
crazy, the 1400 is for the short block only right?
TT LSA/6L90e/9"
Old 03-12-2004, 01:18 AM   #9
Joey-D
Joey-D's Avatar
yep, slap on some big ol' AFR heads and hold the f!ck on>
Old 03-12-2004, 01:34 AM   #10
rogf4
Try Jim Pace he is in Ohio largest gm dealer over 4 million in inventory new crate engine no core charge delivered for about $1350.00 with wty. 3 year 36,000
rogf4 is offline   Reply With Quote
Old 03-12-2004, 01:38 AM   #11
rogf4
Jim Pace sells transmissions also what model are you looking for? if interested let me know I will get the number for you.
Roger
Old 03-12-2004, 04:26 AM   #12
FirstGen
Just Don't Stop!
FirstGen's Avatar
Yeah definatly interested. Looking for a 350 and a 700r4 probably.
Thanks...
TT LSA/6L90e/9"
Old 03-12-2004, 09:12 AM   #13
charles oliver
68 camtruck
charles oliver's Avatar
Jim Pace
Does anybody have an email or web address for him ?
Charlie
71 GMC Jimmy 4X4
68 Huger Orange Camaro 454 with TH400 :gmc
charles oliver is offline   Reply With Quote
Old 03-12-2004, 11:48 AM   #14
Sweet72
Sweet72's Avatar
www.PACEPerformance.com
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 03-12-2004, 06:31 PM   #15
charles oliver
68 camtruck
Thanks for the www.paceperformance.com but it doesn't work
Maybe the site is down right now.
Charlie
71 GMC Jimmy 4X4
Old 03-12-2004, 11:40 PM   #16
jhow66
jhow66's Avatar
www.paceparts.com
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-13-2004, 03:21 AM   #17
Chevyguy111786
i got a motor i'll sell ya, you can come check it out too, it ran great before i pulled it. i'd even help ya put it in just for the heck of it. it's a 350. came out of my 70, i have a 72 corvette engine to replace it.
Chevyguy111786 is offline   Reply With Quote
Old 03-13-2004, 08:57 AM   #18
FirstGen
Just Don't Stop!
FirstGen's Avatar
Cool, any idea on milage on the 350? How much you wanting for it?
TT LSA/6L90e/9"
Old 03-13-2004, 11:43 AM   #19
walker
walker's Avatar
The new GM crate 350 is $1350 with a 3 year 50k warranty. I did it a while back. If I had it to do again I would void the warranty and put in a new cam and put my performance heads before I put it in.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 03-13-2004, 11:47 AM   #20
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I did the same thing walker did and I would also step up and void the warranty but it's fast in a heavy a$$ blazer..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-13-2004, 12:13 PM   #21
junkyardjohn
junkyardjohn's Avatar
WOW ..... $150 .. THATS CHEAP .. THROW IN ANOTHER $40 OR $50 FOR MACHINE WORK, PERFORMANCE GOODIES, & GASKETS & YOU'LL HAVE A GREAT MOTOR. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-13-2004, 03:44 PM   #22
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
GM also sells a 383 crate motor. It uses a 3.80 crank throw with clearance built into the block for the longer throw and rod clearance.This way the block can use a standard bore so that it can be machined a couple of times for rebuilds.Comes with the GM warranty.Another site is Scoggins/Dickey in Lubbock Tx.Just don't date the ditzy twits if you go to pick one up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-13-2004, 06:56 PM   #23
Chevyguy111786
the 350 has prolly 15,000 miles on it. if i can sell it for 600 or so i will. but today i was talkin to my dad and might try and find a 85 or so with a great body and crappy engine for cheap and through m y engine and tranny in there. but let me know. cuz i can go either way.
