Hotwheels?
Big Starter Problems, Kinda wierd.
Well... I had a VERY strange thing happen today. I went out to start her up right after I had driven her previously... The weather was kinda warm, but nothing she hadnt seen before. It had been about 30 minutes since I had driven her.
So I turn the key and start the ignition, everything starts fine, but the starter sounds like it wont turn off. So I put the key in the off position and the starter wont stop still. I dont know if the thing was engaging the flywheel. Id have to assume not since the engine wasnt making VERY bad noises. So I eventually just pull the negative battery terminal. I put it back on and everything is pretty good except the car wont turn over. Did My starter blow or what? I need to know if I need a new starter... I really dont want to put one on with the headers and all. ![]()
1978 Money Pit - CUSTOM DELUXE!!!! |
#2 | |
Re: Big Starter Problems, Kinda wierd.
Hotwheels?
Hrmmm... Well I checked the battery to see if it was low after everything happened and it still had a solid 12.5V with the ignition off... so im pretty sure its not that. I dont even hear the sucker clicking on/off to engage when I try to engage the starter from the key in the ignition.
#4 | |
You get what you pay for
![]() Join Date: Dec 1999
I'd say your solenoid is shot. Probably has some burned spots on the copper disc on the inside. Don't know the technical name of this piece but have had it happen to me before.
Mike 1985 Chevy C-10 |
Hotwheels?
So??? The solenoid is shot eh? How do I replace this badboy?
Before you go an pull the starter off, try hitting the solenoid with a hammer. I had mine get stuck, so that it had the same problem you described (spinning with no engagment). If this doesn't fix the problem, the replace the solenoid. It should be faily striaght forward.
"When I start my car in the morning I want the neighbors to think the world is comming to an end." Homer Simpson I'm not stuck, I've still got some gas left" |
Hitting it with a hammer may unstick it for now but if disc is burned it will stick again when it lands in the same spot.
Not saying for sure this is the problem but it sounds like it to me. To replace the solenoid you have to remove the starter since the solenoid is mounted to it. If the starter is pretty old, just as well replace the whole thing and be done with it. You can replace the solenoid only but starter motor is probably close to going out also. |
Perhaps since you have headers you could get a mini starter and a heat shield to help keep the starter from getting hot because of the headers.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
Hotwheels?
Well guys. Its not the solenoid... I pulled the starter and took it to the local napa to check if it was faulty and its not. It appears to be the switch... So I have to go digging through the column to find out where the problem is. God this is going to not be fun.
![]() Oh well... atleast I dont have to buy a new starter or solenoid. The whole motor is pretty new and all, so im glad thats not at fault. It does have a "new" column since the truck has been broken into before and I had to replace the column since it got all busted up.
Hotwheels?
Ok, somebody go through my logic here... I dont think its the actual part in the column that the key goes into since the brake light thing on the dash illuminates when I turn it on to the ignition position... Im thinking its further down the dash on the actual ignition part.
Its a really hard thing to get to though. Anybody know what color the ignition wire is? Im really wanting to hotwire it, just to make sure the starter works.
You have to drop the column to get the switch off. Not remove, just drop it down. Not hard to do. The switch is on top of column right behind the dash. It is connected with a rod to the key lock cylinder. Make sure the lock cylinder is in the lock position before removing the switch.
#13 |
Hotwheels?
Thanks swerve... I found where the switch is. Do I have to remove the wheel and everything to drop the column or just take out the bolts and such... My book tells me I have to do a lot of stuff that I dont think would be neccisary.
#14 |
No, just remove the bracket holding the column to the dash. Nothing needs to be taken off. Once the column is loose you can take the switch off.
Edit. You will need take gear position indicator loose. Last edited by swervin ervin; 03-12-2004 at 07:56 PM. |
#15 | |
#16 |
Hotwheels?
Any tips on getting to that switch? Ive loosened the column... but there still isnt much play at all. The switch is in a really nasty spot. And what should I do with it once its out? Just replace it?
#17 |
Hotwheels?
Bump please... Im really stuck.
#18 |
rolf,
Make sure you disconnect the string that is attached to the shift indicator. This will give you a little more play. It's attached to the column with a little clip. Once you get those two bolts off the column you should be able to gently push down on the column enought to get in there. It's tight, but not too bad.
63 Chevy C10 86 Chevy K10 |
