Old 03-12-2004, 04:28 PM   #1
68 Suburban
68 Suburban's Avatar
Should I, or Shouldn't I?
Right now I have a stock 1976 L-48 engine. With tweeking and such, I have gotten it in the 19-20 mpg range on 87 octane.
I have a Mild RV cam and some Vortec heads that I have been wanting to put on the engine. Im worried I am going to ruin my gas mileage. Some say that it will help the mileage. Any comments?
Im also going to be installing the underdrive unit I have.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 03-12-2004, 06:35 PM   #2
bpmcgee
bpmcgee's Avatar
68,
Those Vortec heads are pretty effecient little buggers. They may help your fuel economy. The RV cam I'm not so sure about.
On the other hand, 20 mpg in a 350 almost smacks of alien intervention. I'd be tempted to leave it alone.
Brian
bpmcgee is offline   Reply With Quote
Old 03-12-2004, 06:43 PM   #3
68 Suburban
I am just looking for a little more umfff. Maybe the heads, but not the cam?
Old 03-12-2004, 07:06 PM   #4
Custom 68
Custom 68's Avatar
Chris I bet with that underdrive you will get that umff you are looking for. Will the vortec heads increase your compression? I wonder what that will do. They are a smaller chamber I bet.
with the changes you will certainly get the hp but that "alien intervention" lol of a fuel mileage may go away.
Heck try it, you can always go back
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-12-2004, 07:49 PM   #5
oldsub86
RV cams are supposed to enhance torque and mileage. It should be alright. Not so sure about the heads. You might want to do some more research on that issue and the combination of the two items. Have a look at this http://purplesagetradingpost.com/sum...fo/heads1.html
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 03-12-2004, 08:37 PM   #6
Bowtie67
Bowtie67's Avatar
Post
Efficiency is where it is at, the vortecs are very efficient heads, the L48 heads had 76cc chmbers the vortecs are 64cc, also vortecs came in a few flavors of valve sizes. your stock heads are probally 172/150 valves, if the vortec heads are 194/150 these would be a nice economy head but if you have 202/160 fuel milage will drop. Because of the Chamber of the heads you will be going from 8.5 to 9.7CR and may have to run a higher octane fuel. Raising the Compression and the stock cam may cause some other issues here as well. The stock cams are what they are STOCK and was nevery intended for high compression depending on which RV cam you have will help the overall difference.. Also note that depending how much milage is on your motor could also play a factor of a suddenl CR boost and cause the lower end to go. If your getting good gas milage and things run well. "Don't fix it unless it's broke." If the motor has seen some milage to it and its getting tired, think about a nother block and take you time and put a new motor together and when your done drop it in. JMO
Bowtie67 is offline   Reply With Quote
Old 03-12-2004, 09:24 PM   #7
68 Suburban
The motor only has about 40k on it. The blue smoke at start up is pissing me off.....lol
Old 03-12-2004, 09:35 PM   #8
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The blue smoke at start up is usually you valve seals going bad. My Toyota has been doing it for years now...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-12-2004, 11:30 PM   #9
krue
Designated A-hole!
krue's Avatar
Sounds like valve seals to me.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 03-12-2004, 11:38 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Higher compression can mean higher MPG too though.
In the 70's, one of the hi performance mags took a 67 camarow, and made it a MPG king. High compression 350 that got OVER 20 MPG. I wish I could remember who and what the combo was, but it was pretty cool.
I'd say slap the heads on, dip the cam in it's dippin sauce and stab that sucker.
