03-12-2004, 05:42 PM | #1 |
tire size question
hey guys... have a quick question for you... what size tires would you put on a 68 chevy shortbed with 18" rims and a 2/4 drop?
thanks for your help...
...juju... |
03-12-2004, 05:50 PM | #2 |
ran out of money
i am not sure what size it is but i am running a 255/60/15 front and a 275/60/15 rear nice look IMO.
but you might also want to give a width you are going to run...... might be more helpful to others Rat
Modify everything, leave nothing alone!~ |
03-12-2004, 05:52 PM | #3 |
Id go with something like 260-290 ( Im not sure what 18's come in) by 50/55/60/65? Imo that will give you enough meat to fill up the wheel wells and look good
03-12-2004, 05:56 PM | #4 |
This I know...I have 275x60x15's on on fours (15x8) and the fronts are rubbing my lower control arms when I turn to short. Needless to say I will be switching to 255's on the front. If I would have been a little smarter I would have first checked with this board for advice.
03-12-2004, 06:09 PM | #5 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
03-12-2004, 07:12 PM | #6 |
My fronts are 18x8 with 255/45s. This shot shows it with 2.5" drop spindles. I plan to go lower...
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
03-12-2004, 08:25 PM | #7 |
I remember one member in CA had 285's on 20's. It was a really tight fit, but it worked.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
