03-13-2004, 10:58 AM | #1 |
HEI Wire
I'm sure this has been covered many times,but what do I have to change when converting to a HEI dist . If I remember there is a easy conversion by swaping out a wire in the bulkhead connector? or am I having a brain fart ?
Where Am I ? How did I get Here ? 1970 K-10 292 Longbed stepside (now a stakerack)powersteering ,Factory step bumper,Tow Hooks,Deluxe gauges Tach & Throttle, 4 speed manual 1 out of 464 made with protectoplate intact . |
03-13-2004, 11:20 AM | #2 |
Inline 69
heres a link to for hei install. http://67-72chevytrucks.com/vboard/s...threadid=13698 jeff
03-13-2004, 11:24 AM | #3 |
Just change out the original resistor wire to the dizzy with a non resistor wire. Also, need to remove the wire from the starter solenoid that supplied 12v to the old dizzy during starting. Piece of cake.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
03-13-2004, 11:28 AM | #4 |
Thanks will do so,I just did a search and found the same diagram,yes it does look easy !
