Old 03-13-2004, 11:45 AM   #1
70-K10-292
Pedal pads
How are the (brake/clutch) pedal pads held on ? Mine even when new would eventually fall off after catching it with my toe. were they glued on from the factory? Mine are all now cracked around the edges allowing them to fall off,they look almost too small !Would it make a diiference when new to heat them up in hot water before installing new ones ?
Where Am I ? How did I get Here ?
1970 K-10 292 Longbed stepside (now a stakerack)powersteering ,Factory step bumper,Tow Hooks,Deluxe gauges Tach & Throttle, 4 speed manual 1 out of 464 made with protectoplate intact .
70-K10-292 is offline   Reply With Quote
Old 03-13-2004, 07:44 PM   #2
70-K10-292
ttt
Old 03-13-2004, 09:08 PM   #3
JimKshortstep4x4
Talking
I have glued them on before when I had a problem like that and they held forever after that. I used 3M trim adhesive.
Jim
Old 03-13-2004, 11:13 PM   #4
ZOOMY
glue
Glue them like said with 3M Super Weatherstrip Adhesive, affectionately know as "gorrilla snot". If you get some on your fingers you'll know why. Sand the metal pad on the arm a little & it'll give the glue more "bite".
ZOOMY is offline   Reply With Quote
