Old 03-13-2004, 02:25 PM   #1
Wootdog
Wootdog's Avatar
shaved doors, solenoids, and poppers
Starting the install in a few minutes. I have instructions for the solenoids, but not the door poppers. I did a search, and didn't find anything in reference to XXL who had a good writeup previously. Tried to go to my old truck site and didn't get in. Any help would be appreciated. Thanks in advance Kerry
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 03-13-2004, 09:23 PM   #2
Wootdog
Wootdog's Avatar
TTT
TTT
1969 Chevelle
2002 Silverado LT
Old 03-14-2004, 03:29 AM   #3
lost wages
lost wages's Avatar
i put my poppers in the rocker panel where the lowest door rubber bumper would be, just had to enlarge the hole a little.
lost wages is offline   Reply With Quote
Old 03-14-2004, 02:34 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I put mine on the lower corner on the latch side, the only real poblem I had was the angle of the rocker and the angle of the door would cause it to bind and not close right so be sure to test fit before you make it all perminent.
sneakysnake is offline   Reply With Quote
Old 03-28-2004, 10:30 AM   #5
Wootdog
Wootdog's Avatar
poppers install?
How did you get them in? I tried making the hole somewhat larger. But I don't want to make it too large. I have tried putting a hole on the inside of the truck and looks like I can even do that right. I can not get any kind of tool in there on the inside. I am afraid of messing this up big time. You see if I make the hole larger enough on the outside to get the back of the popper in, I would have to use a large washer to keep the popper from coming out of the hole. With the angle of the rocker, I can not get the washer completely in front of the popper. KInd of a catch 22. All suggestions would be appreciated. I am about to pull my hair out. Kerry
1969 Chevelle
2002 Silverado LT
Old 03-28-2004, 12:13 PM   #6
sneakysnake
Without pics its hard to know exactly what you have, does it not have tabs or some form of way to attach it with pop rivets or screws? I made mine from scratch and welded them in so i cant tell you a solution without seeing what you have to work with.
Old 03-28-2004, 05:17 PM   #7
RON WOODGEARD
Resident Young Old Dude !
Sneakysnake, Can you show him pictures of yours??
I'd like to see some also..
RON WOODGEARD is offline   Reply With Quote
Old 03-29-2004, 12:15 AM   #8
lost wages
lost wages's Avatar
heres where i put mine, im not sure what style popper your using, can we get a pic and im sure someone will be able to help.
